Help, battery issue
Old Jun 27, 2024 | 10:06 AM
pistons4550's Avatar
Help, battery issue
My dumbass hit the positive battery terminal with my wrench and some sparks flew. I checked to make sure everything is ok and all I’m getting on the car is the 3 ACD lights and the door open light. No voltage on the MR gauge or any other dash lights. My AFR gauge flickers a little. I checked the battery positive terminal fuses and they were fine, checked the battery fuses inside the engine compartment and they were fine. Checked whatever other fuses I thought might be the issue and they were fine as well. Car won’t start obviously. Had to go back to work and not sure what the issue is. Thoughts? I’m sure it’s something dumb I can’t figure out.
edit: I see now in darker lighting it just all the dash lights are on, just very dim. My battery reads good voltage off my multimeter but 0 on my MR cluster gauge.
Old Jun 27, 2024 | 11:26 AM
ViciousLSD's Avatar
try bypassing that main fuse in the fuse box
Old Jun 27, 2024 | 11:32 AM
the 60 amp fuse that’s screwed in, closest to the front of the car?
Old Jun 27, 2024 | 11:55 AM
ViciousLSD's Avatar
yes, add wire from (+) batt post to left fuse bolt. see if the power to interior is stabilized. check your battery charge also. might be too low
Old Jul 10, 2024 | 12:19 AM
ChristianRay's Avatar
Thank you so much for the information.
Spoiler
overdrive1
Jun 1, 2022 08:54 AM
Venom_x
May 24, 2018 04:11 PM
killercd4G63
Mar 3, 2012 08:33 PM
EvolNinja
Jul 17, 2008 05:49 AM
LancerMMC
Lancer Troubleshooting
Oct 6, 2005 08:15 AM
