Bottom Bolt for Upper Timing Cover Evo 9
Old Jan 8, 2026 | 09:17 AM
dekorum's Avatar
Hi guys,
Previous owner put on one of those clear Evo 9 upper timing belt covers. The bolts were almost all gone so I got the 4 proper OEM bolts and all but one go in. It seems like the bottom left bolt has no where to screw into.
Am I missing a piece? The bolt goes through an unthreaded piece from the black lower timing cover but nothing threaded.
Thanks!
Old Jan 8, 2026 | 09:22 AM
dekorum's Avatar
Kind of hard to see it in my photo so I will try to upload a video. You can see the black lower cover piece seems to be able to flop around but it’s not threaded. Is it supposed to be able to move around like that?
File Type: mov
Old Jan 8, 2026 | 09:44 AM
schuhie's Avatar
If you look at this diagram, it sort of looks like you might be missing 02012P? Its hard to say from the picture and I can't open the video right now.
https://stmtuned.com/products/1062a0...Tdsw3ZrfHCNvTk
Old Jan 8, 2026 | 10:06 AM
dekorum's Avatar
That was my initial thought. How is that installed? I wonder if I would need to remove the lower cover for that to be installed.
Old Jan 8, 2026 | 10:12 AM
dekorum's Avatar
Tried to get a few better pictures.
Old Jan 8, 2026 | 11:11 AM
schuhie's Avatar
Yeam, you are missing that bracket for sure. It does look like you have to at least loosen the lower cover to kind of tip it out of the way at a minimum but it might need to come off completely.
Old Jan 8, 2026 | 11:58 AM
ViciousLSD's Avatar
this one?
https://stmtuned.com/products/metal-timing-belt-upper-under-cover-oem-evo-9
Old Jan 8, 2026 | 12:37 PM
schuhie's Avatar
yup, that the one
Old Jan 8, 2026 | 01:46 PM
dekorum's Avatar
Oh yeah that is it. I have something similar on the right side (front) which the lower right bolt screws into.
Do you know what those 2 bolts mount up to? I get that you would need to lift the lower timing cover to slip that bracket behind but I wonder if I will be able to mount it properly.
Old Jan 8, 2026 | 02:11 PM
ViciousLSD's Avatar
chances are one bolt is behind the mivec gear
Old Jan 8, 2026 | 02:21 PM
dekorum's Avatar
I see the two bolt holes in that pic. Thanks for that! Looks like I won’t be replacing this timing cover bolt. It is definitely something to do when doing a timing belt job. I’m not sure why my previous owner removed this darn bracket when he changed the timing belt.
mrfred
19
Jul 13, 2014 05:31 PM
izabran
Jan 22, 2012 08:24 AM
bnr34rb26dett
Jan 22, 2011 12:41 PM
soldave
May 18, 2009 06:41 PM
