alignment settigns
Old May 4, 2004 | 02:09 PM
chickenbrest's Avatar
alignment settigns
I need some help. I have installed GT Spec Front and rear strut bars, and a 25 mm Perin Rear Sway bar (it is set to the softest setting).
I am installing a set of Tein S-Tech springs this weekend. Then I will be off to get an alignment. I need help deciding on what setting to use for the alignment. I was thinking something like:
zero toe
2.0 camber in the front
1.5 camber in the rear
This is just a guess from reading. I really don't know what to try.
I appreciate any suggestions.
thanks,
-Doug
Old May 4, 2004 | 02:13 PM
Karash's Avatar
In a related question, my tire/alignment shop here had no idea how to adjust the camber of the Evo. They kept on saying they needed to replace the bolt with a shorter one. Any ideas on what to tell the shop on how to physically adjust the camber?
Old May 4, 2004 | 06:52 PM
GDB's Avatar
GDB
You probably will receive better answers by posting in the suspension forum, or doing a search.
ANYWAY...
Do you track/auto-cross your car? If not, I'd say:
-1+ front
-0.5+ rear
neutral toe
... is adequate. Why place unnecessary wear on the tires if 100% of the time it'll be on the street?
If you do track:
max out front (I believe -2)
-1+ rear
neutral toe
Worked wonders for my car when it was stock.
Old May 4, 2004 | 07:53 PM
thanks and I will post it there....
shLa11
Oct 21, 2012 06:28 AM
Clipse3GT
12
Jul 25, 2009 01:26 AM
Mr. MR
Jul 22, 2005 03:00 PM
chickenbrest
23
May 19, 2004 02:03 AM
s4awd
Jun 15, 2003 01:07 AM
