How much do they charge for transmission fluid change?
I called Mitsubishi and they told be $90, is that right? I remember I had transmission fluid change at Toyota on my AE86 and it only cost me $16 when I brought my own fluid.
You can do it yourself pretty easily, all you need is a torque wrench and a gear oil pump. runny_yolk did a great writeup in the howto section. I switched to redline MT90 and I swear the shifts are smoother..
nsnguyen: did you go with full mt90 or a mix? i went with full mt90 and i found it hard to get into 1 and 2 and the shifts were harder. i then went with mt90/mtl mix and it was much better.. jsut wanted to see what your thoughts were
hanzo: i paid $20CAD when i brought in my own fluid.. it's two bolts and you just drain it and put the stuff in.. you do need to get that pump though, because there is no way you going to get a funnel up there ..
-joe
-joe
I usually do this sort of work myself, but I've been too busy lately. Also, I suppose it's nice to have it in your service history if you ever run into warranty issues.
Emre
weird.. i had the exact opposite experience.. cold weather was worst with full mt90 but once it warms up, 3-4-5 shifts were very very good but 1-2 shifts required quite a bit more force.. i talked to redline and they say that the mt90 is almost a race fluid and that it's not really designed for cold weather or running conditions
so i talked to some of the bmw guys who run their m3's on the road tracks and they said they had gear chatter with full MTL and notchy with MT90, and they went with 1:1 mix of MTL:MT90 and they say it's best of both worlds, so that's what I did and it worked wonders
-joe
-joe
Ghilversumtuner
Lancer Tranny/Drivetrain Tech
23
Apr 11, 2019 09:28 PM
jrsimon27
Mar 19, 2006 04:45 PM
