Any "Street Trim" Evos hit 200mph yet?....
well....i bought an evo and my goal is top speed so your wrong there....i enjoy track events and the Evo is awesome at that .....thats a given ....but whats a goal without some obstacles......
K, all im saying is that the evo is limited at like 157 by the ecu and wouldnt go much past that anyway becuse 5th gear isnt that long. You would have to change the gearing for it to go 200, and Im sure that it would need considerable power to overcome the air resistance. So IMHO if you wanted top speed, you should have gotten a different car.
Isn't the physics behind hitting terminal velocity something to the effect of in order to go maybe 10% faster, you'd need to make more then 50% more power? I am in no way an engineer, but I remember someone once saying that in regards to the porsche carrera GT
I don't think anyone has spent enough time in a wind tunnel to get this brick up to 200 MPH. With the current Aerodynamics, I'm thinking you'd need 800-900 HP, a very long final drive (or different gearing in the tranny), and ***** the size of your head because of how unstable the car is about 130.
well your evo is a lemon if its unstable @ only 130mph
well i was real close... 188mph gps confirmed... i ran out of highway and before i decided to go again the other direction i checked out my car at a rest stop... i noticed that one of my tires had a plug in it(bought them used)... after seeing that i decided not to run at high speeds again till i get a new set of tires..
btw all the coolant in my radiator had disappeared as well....
if you want a modded compact car that can push to 200mph... you want power and the lowest drag coeficient possible...
one car comes to mind at this moment, which is the g35 coupe which has coefficient of .28 with the aero option. now once you throw a single turbo on and other mods, maybe you can push it to 200mph
