boost gauge tap
Old Sep 13, 2004 | 06:37 AM
bolsen's Avatar
Originally Posted by titaniumkingpin
aiight... new question.
i have it the way most people do. (shorter hose ..right of the dipstick)
i get a consistant reading but its not accurate.
i get a reading of 22 psi tapering down to 19 by redline.
my boost is set to 19.5
i have an autometer ultra lite and the vacum hose is a clear plastic hose that is very thin and cheap looking.
would changing this hose to a rubber vac line help my readings?
You're running a mbc right?
Old Sep 13, 2004 | 07:27 AM
blackevoVII's Avatar
I dont think the hose would make a difference. Its your tap. You could either try the next hose up or the hose that is in the picture on the bottom of page 1.
Old Sep 13, 2004 | 07:47 AM
suicidalsquirre's Avatar
I have the same Autometer gauge with the clear plastic tube. I tapped off the FPR to the left of the dipstick, no problems, rock solid reading. I have 19-20lbs of vacuum at idle, I can rev in neutral to build about 4lbs of boost (BOV vents), and I have it reading 19psi, no flutter or taper. You'll be fine using that as long as its installed correctly with all the connections sealed tightly.
Old Sep 13, 2004 | 10:31 AM
titaniumkingpin's Avatar
i have no idle vacum reading....my boost gauge doesn't show vacum.
Old Sep 13, 2004 | 10:32 AM
and yes, i have a mbc.
Old Sep 13, 2004 | 10:33 AM
should i try tapping into other hoses?
Old Sep 13, 2004 | 10:36 AM
bolsen's Avatar
Did you take out the boost control pill in the line to the wastegate?
That plastic line is tinsy... that's why I used the vaccum line from a hardware store and brass fittings.
Old Sep 13, 2004 | 10:37 AM
chinto's Avatar
you see the picture i posted? tap into that line their if ur hose is long enough if not . the second from the left hose on the throtle bodie i belve it has a blue dashed line on it. ( could be wrong on color ) is the one u want the one a little further away from the dipstick.
Old Sep 13, 2004 | 10:38 AM
siantjab's Avatar
Dito. Mine is perfect and I've installed several more the same way; none have experienced any issues.
Old Sep 13, 2004 | 10:43 AM
chinto's Avatar
working on editing ur picture ill circle where u want to tap if ur line isnt long enough for the place i have
Old Sep 13, 2004 | 10:57 AM
bolsen's Avatar
Ummm, if youre going to edit my picture, you could at least say that both spots will work fine. It makes it look like one way is wrong vs another
Gang a boost gauge only messures pressure inside youre vaccum hoses. Almost any vaccum line will work.
His readings on the boost gauge sound like a result of him pulling the pill out of the wastegate line. That's why he's holding boost to redline where ours tapers off.
Old Sep 13, 2004 | 11:03 AM
chinto's Avatar
well ur tryn to get the most accurate reading possable. both of thoes do work as i stated earlyr and i did say that in the post. dont mean to make ur pic look bad its just a color that stands out and i dont want to be giveing incorrect info but for a better place to tap where the a/f ratio doesnt get changed as it does or could the best place to tap as iv been told by malabuejack ( sorry if iv spelt any thing wrong ) is the vacume line on my first picture where i also have it circled in red if ur vacume hose can reach. if not the best of thoes two vacume lines is the second one where i have circled.
ps
both spots dont allways work fine. they might work but will not allways show correct boost / vacume
Old Sep 13, 2004 | 11:06 AM
ur is your
tryn is trying
possable is possible
thoes is those
earlyr is earlier
giveing is giving
malabuejack is malibujack
spelt is spelled
vacume is vacuum
you spelled alot wrong ( :
Old Sep 13, 2004 | 11:08 AM
chinto's Avatar
Originally Posted by blackevoVII
ur is your
tryn is trying
thoes is those
earlyr is earlier
giveing is giving
spelt is spelled
vacume is vacuum
haha bro u got to much free time remind me to use u as my spell check from now on and ill clean ur engin for you ( once ) u pick when.
Old Sep 13, 2004 | 11:11 AM
ilu
next, we'll work on punctuation.
