How to install the spark plug anti-foulers to remove the ses or cel light
Subscribe
Apr 8, 2009 | 09:22 AM
  #106
do you have to disconnect the battery? can't i just clear my code with my OBDII Scanner?
Reply 0
Apr 8, 2009 | 10:05 AM
  #107
If your software will clear it, it will clear it... follow? Go plug it in.
Reply 0
Apr 8, 2009 | 11:38 AM
  #108
i am saying when i do this antifouler install, do i have to disconnect the battery?
Reply 0
Apr 8, 2009 | 11:43 AM
  #109
No, unless your removing your DP, which is very close to the Neg. cable on your starter.
Reply 0
Apr 8, 2009 | 12:09 PM
  #110
cool so i dont need to disconnect it. thanks guys for the help!
Reply 0
Apr 20, 2009 | 07:38 PM
  #111
I recently bought an O2 fix on eBay for 18.99, installed it and after the second time I turn my car on I get the P0141 code. This is bull*hit! I guess I'll just drive for a while and see if it turns off.
Reply 0
Apr 20, 2009 | 08:01 PM
  #112
Quote: I recently bought an O2 fix on eBay for 18.99, installed it and after the second time I turn my car on I get the P0141 code. This is bull*hit! I guess I'll just drive for a while and see if it turns off.
do u have a pic of it? u might need to put two foulers sometime to get rid of it.
did u actualy have the code prior to installing the exhaust?
Reply 0
Apr 20, 2009 | 10:42 PM
  #113
Did you reset the code or ecu after the install?
Well the suggested method in the beginning of this post fixed my code for over a year now without a sign of fault.
Reply 0
Apr 20, 2009 | 10:52 PM
  #114
Yaaah, that's what i NEED to do....had my engine light on for over 4 years now, bahahha!
Reply 0
Apr 21, 2009 | 07:17 AM
  #115
Quote: do u have a pic of it? u might need to put two foulers sometime to get rid of it.
No I don't have a pic it was the one for 18.99. I guess I'll buy another one and try it. I've had the code prior to installing the O2 fix since I'm running a testpipe.
Reply 0
Apr 21, 2009 | 07:19 AM
  #116
Yes I cleared the code twice. How many O2 fixes are you using?
Reply 0
Apr 21, 2009 | 07:59 AM
  #117
I am using 2, but ur actual O2 sensor might be bad, that's why i asked if u have had the code before u put the test pipe on.
Reply 0
Apr 21, 2009 | 06:09 PM
  #118
Quote: Yes I cleared the code twice. How many O2 fixes are you using?
I'm using 2 as well.
Reply 0
May 20, 2009 | 06:58 AM
  #119
Awesome Write up! what a cheap way to get rid of the SES light. I did it about a week ago and, i havn't had the SES light since THANKS!!! I'm only using one on my test pipe, no issues at all.
Reply 0
May 26, 2009 | 07:36 PM
  #120
Very nice. I have the stock downpipe but are soon getting a TBE. I was bored today so decided to give it a try. Everything went smoothly and it works just great. No light no nothing. Awesome! cant wait for the straightpipe now
Reply 0
