How to install the spark plug anti-foulers to remove the ses or cel light
Old May 25, 2006 | 08:55 PM
  #46
Tainted Winter's Avatar
Is the CEL trown by an "over lean" mixture? Has anyone pulled the code? It seems that the only thing this mod, and RRM's version, does is limit the amont of gas that passes through the O2 sensor. If the CEL was somethig else, this theoretically wont help, right?
Old May 26, 2006 | 06:22 AM
  #47
EvilBlueEvo8's Avatar
correct. this mod limits the amount of hydrocarbons and other polluting molecules in the exhaust from being measured. its basically only preventing the cat inefficiency code.
Old May 26, 2006 | 06:33 AM
  #48
BaLListic_EVO's Avatar
btw for those needing a shorter setup. possibly running catless stock exhaust. You can take 1 anti fowler and drill it almost to the end very close then get a few washers and stack up then thread the o2 back in works like a charm on the stock exhaust....
Old Jul 8, 2006 | 12:27 PM
  #49
SiCKlEyWiKeD's Avatar
anyone have this on the helix?
Old Aug 27, 2006 | 05:07 AM
  #50
SuperStreet2K6's Avatar
does this work for the EVO IX?
Old Aug 27, 2006 | 11:55 AM
  #51
Evo9"Miss Rose"'s Avatar
^^^im pretty sure it does!!! i just got my SES light on today soo imma try this METHOD!! sounds eazy and cheap and it Does the job
Old Aug 27, 2006 | 12:37 PM
  #52
I just did it on my IX MR and it worked so far.
Old Aug 27, 2006 | 12:47 PM
  #53
Z_Lancer_Man's Avatar
This works great. 18 months running it and still no SES light.
Old Aug 27, 2006 | 05:15 PM
  #54
Great! Hopefully mine lasts like that too!
Old Aug 30, 2006 | 08:56 AM
  #55
MR. stEVO's Avatar
ok...for the people like me that has the hks cf ti exhaust my friend and i made a 90 degree anti fouler..ill post pix of wat we made..works great..no cel..we might even make some if people need them...
Old Aug 30, 2006 | 11:50 AM
  #56
M00kiE's Avatar
ive been running this setup for several months now.. have reset my ecu a couple of times and still get a light.. any other ideas? what is wrong with "cleaning" the sensor?
Old Sep 10, 2006 | 06:23 PM
  #57
4cdndctn's Avatar
works with WORKS. No CEL for 1hr which is a long time when your used to code tripping within 10 minutes of driving after a batt terminal disconnect.
Thanks
Old Sep 17, 2006 | 03:58 PM
  #58
scoob2evo's Avatar
GREAT WRITE UP!!!! Just what I was looking for... thanks again!
Old Sep 17, 2006 | 11:30 PM
  #59
Little China's Avatar
yeah, my light keeps coming on no matter what i do..... put one drilled in and it worked for about 5 miles, then came on..... and it rattles on the underbody, no room for two so i tried a 90 deg. elbow.... worked for 15 miles, then the light is back on..... idono what the hell is up with this thing.
Old Sep 18, 2006 | 01:04 AM
  #60
So how exactally does the sensor read... does it measure well for X amount of exhaust passing by the nox count should be Y, or is it just a general reading of Y is how much nox the sensor should see all the time?
