How to install the spark plug anti-foulers to remove the ses or cel light
Old Nov 7, 2008 | 07:25 AM
  #91
Davo's Avatar
there are 2 different lengths in the Help brand
with the shorter of the 2, u will need to the 2 in the pack
with the longer set, some have reported good luck with just the use of one
They are a long term soln.
This thread has all the info u need
Old Nov 11, 2008 | 01:01 PM
  #92
ugakirk's Avatar
Great job. My o2 sensor still won't fit in there so i mite need to drill it out a little more.
Old Nov 11, 2008 | 01:02 PM
  #93
ugakirk's Avatar
Yep works like a charm
Old Nov 11, 2008 | 02:07 PM
  #94
YeaIbOOst's Avatar
gotta do this asap
Old Nov 20, 2008 | 02:18 PM
  #95
YeaIbOOst's Avatar
im doin this mod tomorrow. Now i know when you do this it takes the check engine light off but i heard the code is still there for awhile. How many miles do i need to drive for the code to be totally gone. I need to get inspected soon and even though the CEL is gone im nervous the code still may be in the obdII
Old Nov 20, 2008 | 02:21 PM
  #96
Positron's Avatar
Just d/c the battery for 30 min. the hard code will be erased.
Old Nov 20, 2008 | 09:03 PM
  #97
Zeus's Avatar
Remember that you have to take the car over 60mph (IIRC) to get a read. Otherwise, if you yank the neg on the battery, put it back and put right over to the inspection station, you will get a "not ready" code and fail. Then the inspection guy will think "what's he hiding", and might "look closer". Ask me how I know...
Old Nov 20, 2008 | 09:04 PM
  #98
Zeus's Avatar
BTW, you can just d/c the battery, pump the brake a few times (brake light drains the battery), and connect it right back up on my VIII.
Old Nov 28, 2008 | 11:05 AM
  #99
SAMIV80's Avatar
I have a 05 VIII and it hits the floor board. I had the reweld a o2 bung to get it to fit, but it works like a dream. No cel for 5k miles
Old Dec 4, 2008 | 09:44 AM
  #100
lowkey's Avatar
Registered User
Got the p0420 code this morning (cold morning in DFW, Texas) on my Evo 10 with high flow cat. I’m going to do this fix again because it worked perfectly on my previous 8 for a couple of years. Only one correction though, I believe a 1/2 inch drill bit is too large, there will be no threads left on the fouler. I think you have to use a 3/8 or maybe a 25/64 bit.
Old Dec 4, 2008 | 01:31 PM
  #101
YeaIbOOst's Avatar
1/2 inch worked perfect for me, just be careful thats all
Old Dec 4, 2008 | 06:35 PM
  #102
fasterthanrays's Avatar
I swapped my Perrin catback for a cobb and now I have the same problem. I bought a CEL fix off ebay. Hopfully that'll fix it since it has a 90degree bend in it.
Old Dec 4, 2008 | 08:43 PM
  #103
lowkey's Avatar
Registered User
Thanks. Did you drill from the inside (where the threads are) to the outside, or from the outside (where the small hole is) to the inside?
Old Dec 5, 2008 | 06:54 AM
  #104
Lil red '03's Avatar
Subscribed.
Going to need this when i get home next yr.
Old Jan 23, 2009 | 11:14 AM
  #105
detroit pistins's Avatar
where could I buy that antiu fouler from? would autozone have it?
Thanks
