Why Is my Turbo Timer not Working?!?!
Old Feb 20, 2005 | 08:46 PM
ringovero's Avatar
My Greddy Turbo Timer does not keep my engine running after I remove the key fom the ignition!!!!! It appears to be properly wired, as I can see it adjust the cool-off period as I run the Evo harder. It just turns off once you turn off the vehicle. Sometime it even makes a "buzzard" sound, cars stays on for ~2 seconds, then turns off. Yes, my E-Brake is up.
I bought the car with the unit already installed, but it started doing this after it came back from the shop (I had the shortblock replaced....long story). Car was inoperative for ~4 months .
I'm thinking that if nothing works, I'll probably remove the unit and wire it with a harness instead.
Thanks,
Eddie
Old Feb 20, 2005 | 08:50 PM
evo_whiplash's Avatar
Sounds like they might have messed up the wiring. Maybe they disconnected the ebrake wire.
Old Feb 20, 2005 | 10:41 PM
jonduke's Avatar
safety feature with the e-break ground(check it)
Old Feb 21, 2005 | 06:32 AM
ringovero's Avatar
I'll check that. thanks
cky3396
124
Jul 6, 2012 04:02 PM
4wheelsqueal
Dec 30, 2011 01:40 PM
GearDownSon
Jul 23, 2010 07:47 AM
gudmundur
11
Jul 19, 2008 01:21 PM
Blue car
Nov 15, 2004 08:24 PM
