Quaife Front LSD Install
Old Aug 10, 2005 | 01:09 AM
  #31
hueman's Avatar
any long term reliability reviews?
Old Aug 10, 2005 | 07:11 AM
  #32
Evo8RA's Avatar
Originally Posted by marksae
I've been running in Street Mod. I'm sure you can run the front LSD in the stock classes since the 04 RS's and all 05s come standard w/ a front LSD.
You can run the Quaife in Street Prepared, but an aftermarket limited slip is unfortunately not legal for Stock class. The Stock class rule reads that limited-slip differentials must be standard. The definition of standard reads that it is an item that could have been installed on the factory production line. This may permit use of the RS diff it you wanted to retrofit it, but not a Quaife. I love my Quaife for Street Prepared.
Mark
Old Aug 10, 2005 | 10:39 AM
  #33
evo8usa's Avatar
Mark
Thanks,
I am strongly considering switching to an SP class next year (whether they move the EVO to BSP or keep it in ESP), and I think the Diff is a must have for the 03 EVO (I'm tired of smoking one wheel). That and I got to drove a car on race tires this year and it was addictive.
Old Aug 10, 2005 | 11:29 AM
  #34
EVIL_EVO_VIII's Avatar
I wish someone could install those here in FL. I have a friend thats a mitsu tech but dont know if he can do it. Nice install write up!
Old Aug 17, 2005 | 02:58 PM
  #35
arpad's Avatar
How much time do you think this would add to a clutch swap?
Old Feb 23, 2006 | 10:29 AM
  #36
marksae's Avatar
Can one of the mods update the install thread based off this thread? I fixed all the broken picture links in this thread and need the other thread to mirror my edited posts. Thanks!
Old Aug 6, 2008 | 11:51 AM
  #37
20austin08's Avatar
do the o rings have to be replaced? Where can they be obtained?
Old Aug 6, 2008 | 12:11 PM
  #38
marksae's Avatar
If you're careful when taking the t-case cover off, you should be able to re-use the o-rings. I'd order the o-rings from RRE just in case. They're relatively inexpensive anyway. Just make sure you lube the o-rings before putting parts back together. This will ensure that they won't get caught on anything and rip.
Old Oct 17, 2008 | 12:13 PM
  #39
EvoIXMR's Avatar
anyone know the sixe of these o-rings and if I can get them locally? I need to get the seal replaced on the tcase and considering pulling the cover off. Please help ASAP. I need car running tonight!
Old Oct 17, 2008 | 01:46 PM
  #40
marksae's Avatar
Your best bet is to either call RRE and ask, or you can just pull the o-ring off and bring it to your local Kragen to find a matching replacement.
Old Oct 17, 2008 | 03:12 PM
  #41
bchappy's Avatar
what would be the differences felt by the driver with a quaife vs. a RS FLSD?
Old Oct 18, 2008 | 06:41 AM
  #42
EvoIXMR's Avatar
I got lucky and installed seal without taking cover off...PITA to do, but worked Ok. No leaks thus far
Old Dec 1, 2009 | 11:02 PM
  #43
kyoo's Avatar
REVIVE -
does this work better than the OEM helical front lsd?
Old Dec 3, 2009 | 08:07 AM
  #44
arpad's Avatar
AFAIK yes, but I couldn't tell you why. It also is able to handle much higher power levels without breaking.
Old Jan 7, 2010 | 11:32 PM
  #45
TheMadScientist's Avatar
When you put the diff inside the carrier do you add fluid to the carrier or does it somehow get fluid some other way?
