Remote programming??HappyThankyouDay
Old Nov 24, 2005 | 08:27 AM
sethzx10's Avatar
Got a new remote and im trying not to go to the dealer for anything. The thread that Aussi posted on programming/keyless entry, my computer will not open it up. I have a CD manual and i can not find imfo on remote programming on it.. Is there some where else i could find remote programming/keyless entry imfo???
HELP!!
Old Nov 24, 2005 | 10:35 AM
elhalisf's Avatar
i tried that DIY, and i could not get my car into programming mode. i need help too
Old Nov 26, 2005 | 05:31 PM
2003LancerEvo's Avatar
I was looking for replacement keyless entry remotes not too long ago and I found a site that had them for Evo and Eclipse
I had them delivered in less than a week and the programming instructions only took maybe 10 seconds?
Anyways, here's a link to the site:
Https://www.ThePartsYouNeed.com
Just click the Mitsubishi category, or type LANCER in their search box.
Old Nov 26, 2005 | 05:33 PM
Oh yeah, the instructions I have are:
All you have to do is insert your key into the ignition but leave your key off.
Insert a jumper wire between Pin 1 and Pin 4 on your DLC.
(Pin1 is farthest left on the larger side of the DLC. The DLC is mounted under the driver side dash pointing straight down.)
Once you have the pins shorted immediatly press your hazard switch on and off six times.
Your locks will then unlock then lock.
Press the lock button on your new remote three times in one minute and thats all it takes.
You can follow the same procedure again if you have more than one remote. I currently have three remotes programmed.
Old Nov 26, 2005 | 05:51 PM
elhalisf's Avatar
thanx for the info. i am going to try it out now.
Old Nov 26, 2005 | 05:52 PM
elhalisf's Avatar
ohh and what do you mean leave the key off. do you mean just put in the key without turning it?
Old Nov 26, 2005 | 11:40 PM
elhalisf's Avatar
IT WORKED. finally after 2 months of trying. thanx for the info.
btw did u buy the one with the trunk button? does it work?
Old Nov 27, 2005 | 01:50 PM
sethzx10's Avatar
I tried the DLC wire jumping I most be doing something wrong. I tried putting a wire between pins1 and 4 which are empty slots. 1 and 4 has something in them. can someone post some pics or am i puting the wires in the wrong slots.. My remotes are lock/unlock only no truck button. Seems pretty easy if thats how it works..HELP!!
Thanks
Old Nov 27, 2005 | 02:11 PM
elhalisf's Avatar
the slots are actually number with very very small numbers. they should not be empty slots. make sure slide the wire inbetween the metal. as soon as thats done, immediatley press the hazard 6 times.
also make sure the key is on the 2nd position (out of 4 positions)
Old Nov 27, 2005 | 09:47 PM
sethzx10's Avatar
I'll try again. so when u insert the key turn it to the first postion? Puting a small wire in the #2 and #3 pins, and immediatley press the hazard 6 times. Im not sure if im grounding the pin holes right. Sorry to be a pain....
Old Nov 27, 2005 | 09:50 PM
elhalisf's Avatar
not 2 and 3, 1 and 4.
dont ground anything. thats the mistake i did before. just get a wire, and insert the ends in #1 and #4 pins.
Old Nov 28, 2005 | 03:47 PM
sethzx10's Avatar
HOLEY ****T IT WORKED!!!!!!!!!! Now i need to get some extra keys. i only have 1.
Thanks u guys,,, G.L.O
elhalisf--u da man....
Old Nov 28, 2005 | 03:53 PM
elhalisf's Avatar
Old Sep 14, 2009 | 09:30 PM
Z_Lancer_Man's Avatar
I know this is almost 4 years old, but in case anyone else finds it, I thought I'd re-iterate the process that just worked for me (2006 USDM Evo IX):
1) Insert key and turn to first position (ACC)
2) Jump pins 1 and 4 on the OBD-II connector
3) ** Here is the key - immediately after jumping the two pins, press the Hazard Light Switch 6 times within 10 seconds.
4) The doors will lock and unlock, confirming that you are in programming mode
5) Press the Lock button 3 times (once, then two more times) on the first remote to program
6) The doors will lock and unlock again, confirming the successful programming of the remote.
7) Repeat step 5 for all other remotes, up to 4.
8) To exit Programming mode, do one of the following:
a) Turn the key to off
b) Remove the key
c) Remove the jumper wire
d) Do nothing for 1 minute
9) After exiting programming mode, its always a good idea to test out the remote to ensure the doors lock and unlock as commanded.
Note: Once you enter programming mode, all previously programmed remotes will be erased, so be sure to reprogram all the remotes you would like to use, up to 4.
Note: The driver door does not need to be closed.
Note: If a remote is not programmed within 1 minute of the doors locking and unlocking, the car will exit programming mode, and all remotes will remain erased.
Hope that helps someone in the future!
Old Apr 20, 2023 | 06:55 AM
Kalazoa's Avatar
b) Remove the key
This is pertinent to me because I'm now learning to become a programmer. I am always acquiring fresh knowledge that I need for myself. I've started coming here more frequently as of late. There are lots of helpful articles where I can learn useful programming advice https://www.programmingassignment.ne...ramming-tools/ . I was reading about the top software development tools only the other day. Now that I've learned about the list of programming tools available, I can help you achieve. This is an excellent resource.
Thanks for the step-by-step instructions, I could use them even now.
DannyMR
Feb 27, 2023 03:12 PM
fafaforza
Apr 20, 2016 04:17 PM
zerocool_b
Oct 3, 2015 06:04 PM
Lancer_GTS_740
Lancer Troubleshooting
Apr 26, 2011 09:22 AM
RedEcotecSS
May 10, 2009 08:29 PM
