T-Bolt Clamps (How to and list)
Old Jul 31, 2007 | 01:34 PM
  #46
ElectricEvoIX's Avatar
information much appreciated
Old Aug 1, 2007 | 08:13 PM
  #47
XtoEvolution's Avatar
I just got my clamps 2.5" from siliconintakes and I cant get them on. They seem way to small. How can I measure them to make sure they sent me the correct sizes, because I have the feeling they sent me a size too small.
Old Oct 10, 2007 | 03:31 PM
  #48
hokiruu's Avatar
SiliconeIntakes.com now offers a "Cajun Power Evo package deal." This kit uses the 3" clamp for the throttle body and all 3 1.5" clamps for the DV. They have been out of stock on the 2" for some time now so you can't oder the kit.
Since I am replacing one of my intercooler pipes right now I figure now is a good time to upgrade to T bolts and metal DV before winter hits. I can't wait any longer for the 2" to come back into stock so I went ahead and ordered what I could and what most of you seem to agree works:
1 x 2.75" TB clamp NOT 3"
7 x 2.5" clamps
Not bothering with the the 1.5" DV clamps at this time.
I was going to get the 2" from my local NAPA but they are retards who are impossible to communicate and deal with so I am now not sure where to get the 2".
I am probably going to order from this place (even though they are alot more expensive):
http://intakehoses.com/Merchant2/mer...gory_Code=TBC5
However, since they list different clamps according to INNER diameter in BOTH silicone and rubber I am alittle unsure which size will be correct. I *THINK* what they list as the clamp for 2" INNER DIAMETER BLACK RUBBER HOSE Is what I need. I am placing an order now. If you know for a fact that this is incorrect please let me know so I can change the order. Otherwise, I'll let you know how it turns out.
Old Oct 29, 2007 | 07:17 AM
  #49
MR Turco's Avatar
Does anyone know the size of the MAF outlet? The stock clamp keeps breaking on me.
Old Oct 29, 2007 | 07:35 AM
  #50
hokiruu's Avatar
sorry I forgot to post that the 2" clamps from that intakehoses link i posted were too big for the LICP. I'd say about .25" too big.
Old Oct 29, 2008 | 07:55 PM
  #51
EatSleepBoost's Avatar
bump for a great thread. Just ordered my set. the site silicone intakes updated their site with cajun power's list. all u do is add to cart!
here is the link..
http://www.siliconeintakes.com/detai...004970a208d157
Old Apr 25, 2009 | 06:24 AM
  #52
ribbie78's Avatar
great old thread; just ordered a set. Thanks Cajun!
Old May 8, 2009 | 09:22 PM
  #53
TommiM's Avatar
What about the t bolt clamps from Turbohoses.com? I ordered a set of intercooler outlet hoses from them. Came with really nice Tbolt clamps. QUality of their hoses are excellent. Just curious what everyone else thinks of them.
Old May 8, 2009 | 09:26 PM
  #54
genma's Avatar
Best information I have seen in a while.. Thanks for the time and research!
Old Aug 19, 2009 | 10:15 AM
  #55
supeazn's Avatar
subscribed
Old Oct 16, 2009 | 10:31 AM
  #56
Greenspeed's Avatar
This is awesome. Thanks for the info!
Old Oct 16, 2009 | 10:39 AM
  #57
funks's Avatar
Originally Posted by mooreboost
Hose clamps tighten by a screw biting into serrations on the band itself. They are pretty weak and dont clamp well, thus not holding much boost.
T-clamps tighten by a nut running down a bolt. It is much stronger and holds much more boost.
Some worm type clamps are good - especially the ABA or the AWAB ones (same manufacturer) used in boats and stuff.
Has smooth inner band and rolled edges so it doesn't mess up the hose..
I bought the silicon intakes T-BOLT set, had to replace 2 of the 2.5" of them because they were too small (intercooler coupler) - got better fitting T-BOLTS from my local "Hose-Man". The others 2.5" ones seems to fit but the bolts have too much thread sticking out (are we supposed to dremel em?) . For the 3 - 1.5" clamps used in the diverter valve, I used AWAB clamps instead (much easier to get on).
If i were to do it all over again, I would have bought properly sized AWAB clamps instead. Don't really like these T-bolts, seems a bit big for the application (maybe just these Silicon Intake Clamps, the local hose-man t-bolts that I bought seems to be sized better, but I didn't want to waste my money replacing all of them).
These should work (AWAB) - pricey though.
QTY: 7 - AWAB-316076 (2" -> 3") - QTY 1 - Also Known As ABA (#40)
QTY: 1 - AWAB-316083 (2-1/4" -> 3-1/4") - Also Known As ABA (#44)
QTY: 3 - AWAB-316044 (1-1/4" -> 1 3/4") - Also Known As ABA (#20)
QTY: 2 - AWAB-316064 (1-1/2" -> 2 1/2") - Also Known As ABA (#32)
Old Dec 29, 2009 | 02:25 PM
  #58
rickyart23's Avatar
very helpful thanks for the info
Old Mar 22, 2012 | 01:55 PM
  #59
mistergomez316's Avatar
For removing the bumper right, you know how there's black plastic bolts to secure the bumper? How do you remove it without breaking it?
Old Mar 23, 2012 | 11:50 AM
  #60
TommiM's Avatar
you want to get a small flat head screwdriver and pop the center head out then you can pop the whole thing out.
