T-Bolt Clamps (How to and list)
Old Jan 29, 2007 | 08:46 PM
  #31
2Devious's Avatar
Woo, old thread. Still needs a
Been meaning to get around to this. This makes it that much easier.
Old Jan 29, 2007 | 08:47 PM
  #32
Deepseadiver's Avatar
Nice post make it a stickey!
Old Jan 29, 2007 | 09:06 PM
  #33
SPANKED's Avatar
Already is a sticky...look in the How To...section.
Are the Constant Torque clamps much better than the T-Bolts? I know both are better than stock I just can't decide on which ones...
Old Apr 23, 2007 | 03:21 PM
  #34
hondafan's Avatar
i just installed mine today from the site provided. seems like i could have used a tad smaller for the factory lower IC pipe/turbo as they are almost maxed out with the 2". and the 1.5" was too big for the BOV connections, bottomed out and not tight. i'm going to try smaller ones there and use the 1.5's for the lower IC pipe and see if they fit.
Old Apr 24, 2007 | 01:37 PM
  #35
BluEVOIX's Avatar
What about using 2.25 for in place of the 2.5's? Would that be a better fit or will it be too small?
According to SI the 2.25's Actual clamping ability is 2.36" to 2.68". So I guess that should be better than the 2.5's Actual clamping ability of 2.60" to 2.91"?
Old Apr 24, 2007 | 03:56 PM
  #36
mrfred's Avatar
Edit: I looked back on my previous entry, and I am using the SI 2.5" clamp. It provides more complete clamping coverage than the 2.25". Just need to dremel off the the excess threads after its tightened down.
Old Apr 24, 2007 | 08:08 PM
  #37
hondafan's Avatar
mrfred, what size are you using for the DV connections? the 1.5" were quite a bit too large for a good seal. all the connections with a 2.5" fit wonderful, just the 2" LICP connections are very close to maxed out and the DV 1.5" didn't seal at all maxed out.
Old Apr 24, 2007 | 09:04 PM
  #38
mrfred's Avatar
I stayed with the stock hose clamps there. As the pipe diameter goes down, it becomes easier to maintain a seal.
Old Apr 24, 2007 | 09:56 PM
  #39
BluEVOIX's Avatar
Check out www.jegs.com they have t-bolt clamps as well, but cost more. Maybe we can get small enough clamps to cover the bov pipes...
Which do you guys think would be better?
T-Bolt Clamp 1.160'' - 1.460'' ID
T-Bolt Clamp 1.410'' - 1.710'' ID
T-Bolt Clamp 1.280'' - 1.590'' ID
Old Apr 26, 2007 | 07:22 AM
  #40
SwabeLife's Avatar
Question
Originally Posted by BoOsTinGEVO190
Using these clamps with samco hoses would not make a difference in size ??
+1 ???
what size for the intake?
Old Apr 27, 2007 | 04:57 AM
  #41
SwabeLife's Avatar
Old Apr 27, 2007 | 04:23 PM
  #42
hondafan's Avatar
it's really not needed on the intake since that pipe is not pressurized.
Old Apr 27, 2007 | 09:58 PM
  #43
Q8_EVO's Avatar
I have the AMS LICP and soon FMIC
How many T Bolt Clamps do I need ? and what are the sizes?
Old Jun 10, 2007 | 06:33 AM
  #44
Q8_EVO's Avatar
siliconintakes is out of t bolts, is there any where else i can buy t bolts?
( same quality, price ..!?!?!)
Old Jul 4, 2007 | 04:58 PM
  #45
Dont Try To Run's Avatar
I just ordered everything too, with the 2.75 though.
TJ
