T-Bolt Clamps (How to and list)
Old Oct 30, 2006 | 09:44 AM
cmz's Avatar
cmz
Cajun - Thanks for putting the shopping list together!
I've taken my UICP on and off so many times now that the worm gear based clamp is a mess.... May as well do them all while i'm at it.
Old Nov 30, 2006 | 03:50 AM
cij911's Avatar
Hey replaced my clamps last weekend and the throttle body definitely requires a larger clamp...I used NAPAs Tbolt for a 3" pipe and it was probably 0.5" too small ....Have any of you experienced the same problem?
Old Dec 2, 2006 | 04:34 AM
arpad's Avatar
Actually, I ordered from the same place that cajunpower ordered from and the 3" was too big... the 2.75" fit perfectly though.
Old Dec 20, 2006 | 11:51 AM
Ev0ikon's Avatar
Yup I went with 2.75" instead.
Thanks for posting OP!
Old Dec 25, 2006 | 10:35 PM
mrfred's Avatar
I bought t-bolt clamps from several different vendors and found the ones from Siliconintakes.com to be the best quality. All stainless steel construction, and the bridge piece is very strong. Their clamps use metric nuts which is nice. Their 2.5" clamp works with all the main IC piping. There is a fairly large amount of exposed thread when snugged down. I used a dremel tool to cut off some of the excess thread. The 2.75" clamp fits the throttle body connection. I didn't bother with the smaller diameter connections because I didn't feel that t-bolt clamps were needed there.
Old Dec 26, 2006 | 12:29 AM
Danny23's Avatar
i have t-bolt clamps on my u and licp,s.You dont have to remove the front bumper to get to any of them at all. Its just a waste of time taking the bumper off. All you have to do is remove the undertray.
Old Dec 26, 2006 | 02:04 AM
Paikman GTR's Avatar
T-bolts definetely are a good and affordable solution.
unaffordable solution however?
Go for Wiggins clamps.
burnsstainless.com
Old Dec 29, 2006 | 05:17 PM
joedr's Avatar
EvoM Moderator
Ordered my set! A definitive add-on for anyone running over stock boost.
Old Jan 8, 2007 | 08:57 AM
hondafan's Avatar
i am having a little trouble seeing the check-out sheet properly, it's a little fuzzy on my screen. could you just list the quantity and sizes please?
Old Jan 12, 2007 | 11:46 AM
grenade's Avatar
1.5 x 3
2.0 x 2
2.5 x 7
3.0 x 1 (But some say that 3.0 is to large, and that 2.75 is good)
Old Jan 12, 2007 | 08:03 PM
mrfred's Avatar
Originally Posted by grenade
1.5 x 3
2.0 x 2
2.5 x 7
If its from siliconintakes.com, 2.75" is the appropriate size for the throttle body.
Old Jan 12, 2007 | 08:09 PM
hondafan's Avatar
and these do still fit with the factory rubber couplings as well, right?
Old Jan 12, 2007 | 08:53 PM
mrfred's Avatar
Yes.
Old Jan 14, 2007 | 08:09 AM
BoOsTinGEVO190's Avatar
Using these clamps with samco hoses would not make a difference in size ??
Old Jan 29, 2007 | 08:34 PM
SPANKED's Avatar
Good info, thanks Cajun!
