Throttle body air leak...Pics inside with how to fix!!!
Old Aug 14, 2006 | 11:12 AM
Spec'd's Avatar
That MachV link was worth bookmarking.
If the DSM seals wont fit, why not order the OEM seals from Mitsubishi ?
Old Aug 14, 2006 | 11:23 AM
nigletsyz's Avatar
mitsu doesn't sell the seals... i already called
Old Aug 14, 2006 | 11:30 AM
Spec'd's Avatar
Those bastages.
So were not supossed to fix our throttle bodies ?
Old Aug 14, 2006 | 02:05 PM
nigletsyz's Avatar
apparantly not, you can only replace the entire unit. Its part #07704 according to the parts catalog. I ordered the replacement seals from MachV. I had them overnighted as well so hopefully by tomorrow evening I will know if they will work or not.
Old Aug 14, 2006 | 06:05 PM
dbdude's Avatar
I ordered these seals as well. $19.00 for two little seals. I have not had the time to fix the leak yet. I am also intimidated about removing and disasembling the throttlebody. Good luck nigeltsyz. Post back your outcome. When i do my repair, im gonna make sure i have plenty of time with no one bothering me in the garage. Also i hope you have a 2nd car just in case.
Old Aug 14, 2006 | 09:53 PM
Spec'd's Avatar
Please keep us posted.
If this turns out right.
Maybe this can become a "Sticky".
If you guys need an FSM, I can show you where to look.
Old Aug 15, 2006 | 02:11 PM
nigletsyz's Avatar
ok guys, i've secured a digital camera to document the process. Wish me luck. If anyone has a shop manual I could "borrow" I'd be eternally grateful.
Old Aug 15, 2006 | 02:22 PM
Spec'd's Avatar
Here's a link from my website
Complete FSM
http://www.4g63t.net/evo_dsm_forum/viewtopic.php?t=77
Throttle Body
http://www.4g63t.net/2005_FSM/GR00003400-13A.pdf
It doesn't appear to give a good breakdown of the throttle
body components.
Old Aug 15, 2006 | 03:03 PM
SRT-TO-EVO's Avatar
Well keep us updated nigletsyz, I would like to know the outcome of this project, and see if these seals really do help keep this leak under control. I had this same exact leak on my SRT-4 at the TB, where the shaft is.
Old Aug 15, 2006 | 05:47 PM
dbdude's Avatar
Any updates???
Old Aug 15, 2006 | 10:08 PM
nigletsyz's Avatar
I took off the TB tonight... the seals didn't come in... Thanks UPS... I will finish this up tomorrow. I will post up some pics of the removal of the TB for now until i finish up tomorrow
Old Aug 16, 2006 | 05:02 PM
dbdude's Avatar
Very good info here. Good job man. Im gonna follow your how to this friday on my evo.
Old Aug 16, 2006 | 11:19 PM
nigletsyz's Avatar
Ok I finished up this project. It held up to 1.5 Bar before my boost leak tester self-destructed. Prior to installing the new seals, it leaked at anything past 2-3psi. I will post up the how-to tomorrow. I took lots of pics (need to resize and edit) and found some better, easier ways of doing the install than the previous how-to for the DSMs IMHO.
I do give credit to the guys who posted up the DSM vFAQ, otherwise I probably wouldn't have attempted this myself.
Old Aug 17, 2006 | 03:37 PM
Evoisdream's Avatar
when u found the leak intially was it really loud and u could feel air coming out i have a leak somewhere in that area but i cant findout where it seems like its coming from the back of the intake manifold.
evoisdream
Old Aug 17, 2006 | 04:57 PM
Spec'd's Avatar
Excellent work !
So is it safe to assume the seals from MachV fit the Evo Throttlebody ?
