Throttle body air leak...Pics inside with how to fix!!!
Old Apr 29, 2012 | 08:25 PM
  #286
evo8lento's Avatar
the new seals were a pain to put in!! but I made them my **** in the end. All looks well now
Old May 30, 2012 | 10:03 AM
  #287
st00pidct9a's Avatar
when installing the new seals id recommend using the metal washer (that is underneath the mini c-clamp and plastic washer) and a 10mm deep socket, then hammer onto the socket to push the seal into place
Old Sep 18, 2012 | 12:17 PM
  #288
amsevokid's Avatar
After fixin the seals my gas pedal became stiff when the car is running. It's stiff for half an inch until I apply more pressure, any ideas
Old Dec 29, 2012 | 01:02 AM
  #289
EvocentriK's Avatar
I got a bit ahead of myself and grabbed some mil.spec TB shaft seals to do this. Did a boost leak test - 35 psi no leaks with original '03 TB seals. Shocked. At least I have them as spares anyway.
Old Aug 3, 2013 | 07:12 PM
  #290
Adi489's Avatar
where would you find these throttle seals for sale?
Old Aug 4, 2013 | 12:33 PM
  #291
rocketmotor's Avatar
Mil.spec and STM have them for sure. I ruined one of the first ones and had to reorder another set. This next time I believe I am going to try to use the throttle body shaft as a guide. I tried to do it free hand and mangled the metal part of the seal on the TPS side that is recessed. The seal that went in well by throttle cable just tapped in gently and it worked much better.
Old Aug 6, 2013 | 07:45 AM
  #292
STM Tuned's Avatar
We have hundreds of sets.
They're for sale too!
Give us a call if you want a pair.
585.226.8226
Old Mar 20, 2015 | 02:21 PM
  #293
TS Dork's Avatar
https://youtu.be/B2ocEdCBHiQ
Leaky seal?
Old Mar 24, 2015 | 03:38 PM
  #294
kaj's Avatar
kaj
Necro bump.
Do the Mil-Spec seals go metal side in or out?
Old Mar 26, 2015 | 10:03 PM
  #295
timmeqn's Avatar
very helpful info. replaced shaft seals with some works seals, but i had such a hard time getting them in I bent them to **** but it was all I had and now I have a pretty big boost leak and my bov is broken lol. Just ordered some mil-spec seals more than one set lol. hopefully I'll get them in right
Old Mar 27, 2015 | 08:43 AM
  #296
kaj's Avatar
kaj
i used a bit of grease. i gently and slowly tapped in the side where the throttle cable goes first. once that was in, i put the shaft through, put the other seal in, then covered it with the metal washer that came off that same side. i used a deep socket that fit over the whole thing and gently/slowly tapped that one it.
i had to use a flat head screw driver to get it seated perfect all the way around.
Old Mar 1, 2016 | 12:26 AM
  #297
deylag's Avatar
I am putting this info together because I had to install some seals for a friend and I found it difficult because I had forgot how to do it. After I got an email back from Aby and doing some trial and error on my own this is what I would think would work best when trying to install the seals.
Originally Posted by aby@mil.spec
I suggest to go buy a 10mm shcs / socket head cap screw bolt that is ~75mm long for example, use a hacksaw or other cutting device to cut the threaded part of the bolt off.
now your left with a smooth 10mm shaft that you slide the seal onto it, up to the head of the bolt & stick that shaft into the bearing / seal bore & pound the head of the bolt forcing / guiding the seal into place.
another option is to locating a socket that fits over the steel part of the seal & use that to help guide you while pounding the seal in.
This is what I had after I followed his advice.
Note: I found that the Mil.spec seals are slightly different. One has a chamfer and the other does not. I put the chamfered Mil.spec seal on the TPS side of the Throttle Body.
Frist I put the seals in the freezer for a couple hours to shrink them. Then I lubed the seals up with di-electric silicone grease. The M10 bolt perfectly centers the seal around the hole. The bolt doesn't allow the seal to move.
Slid the seal to meet the head of the bolt.
Then tap the seals in one at a time on both sides. I used a rubber mallet to hit them in.
Originally Posted by mrfred
The Mil.Spec seals definitely require some force to press into place. A 3/8" dia x 6" long hex bolt cut to a shank length of 3 5/8" makes a great guide to tap the seals in straight.
This works on the same principle as the method I describe.
Sort of the same but a little riskier.
Old May 5, 2016 | 10:57 PM
  #298
Tommyfacekicker's Avatar
That pump is crazy! I'm gonna make one tomorrow
Old Dec 19, 2020 | 10:57 PM
  #299
jackbenimbo's Avatar
Originally Posted by Spec'd
Thanks to you and nigletsyz , this thread will save of us some grief and money.
It's great.
SUPER LATE here but I noticed that the white plastic washer (once tps is removed) was pretty hard to remove without damaging. For anyone doing the seal themselves in the future, it helped to use needle-nose pliers to bite/hold more area of the white washer rather than something like a flathead which could damage or break the washer completely.
jennz03
Lancer Troubleshooting
Feb 20, 2017 08:15 PM
pronage
Jun 12, 2016 01:05 PM
thedru13
Mar 31, 2016 09:08 PM
kobi2002
Mar 25, 2016 03:53 AM
navr11
Mar 2, 2016 11:06 AM
