Throttle body air leak...Pics inside with how to fix!!!
Old Feb 6, 2010 | 12:42 AM
  #256
BLK_EvIL's Avatar
I used the Machv seals they work good no leaks tested up to 30psi might also want to check on the back side mine leaked around the ics and this cap that had like a hex fitting cover on it it has a o ring so i just replaced it and put a little ultra grey rtv on it hasnt leaked since
Old Feb 6, 2010 | 12:15 PM
  #257
blade3609's Avatar
what seals are needed for the TPS side of the throttle body, the same one that is used on the side where the cable goes?
Old Feb 6, 2010 | 12:29 PM
  #258
BLK_EvIL's Avatar
yes ther the same size should come as a set
Old Mar 7, 2010 | 08:59 AM
  #259
blade3609's Avatar
is it a must to remove the butterfly to change the seals? cuz i heard the screws of the butterfly sometimes make a problem when removing and putting back
Old Mar 7, 2010 | 09:17 AM
  #260
mrfred's Avatar
Yes, its necessary because the shaft has to be removed to replace the seals. Its not hard to remove the screws. Just be sure that you are using a good phillips head screwdrive that fits the screws.
Old Mar 7, 2010 | 12:47 PM
  #261
badev0's Avatar
My car has 18k original miles and the they are leaking. Going to replace them tomorrow
Old Mar 7, 2010 | 12:51 PM
  #262
brenner's Avatar
Received my mil.spec seals and TB gasket, thanks Aby. Will install next week
Old Mar 27, 2010 | 01:23 PM
  #263
Foolproof's Avatar
Got my Milspec seals the other day (Thanks Aby) and installed this afternoon. Took maybe 45min tops. Really easy boost leak fix. Write up is on point. If you dont have the spring pliers and are good with small picks you can get it off that way.
Old Apr 2, 2010 | 01:07 AM
  #264
Darwinian's Avatar
I changed the seals and cleaned the throttle body - pretty easy job. Now I seem to have a high idle. Car revs to 1300 and tapers and goes back to 1300 or so. Didn't have that before I did the seals.
Old Apr 2, 2010 | 01:19 AM
  #265
tscompusa2's Avatar
tighten the BISS screw on the throttle body until your idle goes where ecuflash says it should be idling at. You might want to enable the SAS Actuator in evoscan when adjusting it.
Old Apr 9, 2010 | 08:39 PM
  #266
8UpUrV8's Avatar
Is there any special way to set the throttle spring tension??
Old Apr 25, 2010 | 03:08 PM
  #267
600RR's Avatar
I did this today and Idk if it's been mentioned but, I did not remove the tps wiring harness like he did in the write up. I just unbolted the TB first, then unscrewed the tps with it still attached. It was much easier b/c I didn't have a clue as to how to get that metal clip off and no screwdriver I had would get under it.
This is actually quite an easy job. I thought it would be much harder. The coolant lines are probably the hardest part. I had a lot of trouble getting the shaft seal out near the tps. It kept breaking on me, but I eventually got it out.
Another thing I did different was took a sharpie and made a 'line' down the spring before I took it apart so I would know how to align it when I got done.
Old Oct 1, 2010 | 08:23 PM
  #268
YuLost2x's Avatar
where can i get the gaskets from the TB. No one locally here carries them
Old Oct 3, 2010 | 08:59 PM
  #269
ezzey's Avatar
Originally Posted by Soon2BEVO
Damn MachV, what up with that $10 shipping charge on the seals! You could just put them in a regular envelop and ship them for $0.39!!!!
i had to pay 20$ shipping to canada, such ****! lol
12$ for the seals, 20$ FOR SHIPPING!!! sigh lol
Old Oct 3, 2010 | 10:38 PM
  #270
one4's Avatar
https://www.evolutionm.net/forums/ev...available.html
