Throttle body air leak...Pics inside with how to fix!!!
Old Sep 5, 2006 | 11:55 AM
  #106
EvoTech's Avatar
Originally Posted by evoone
METH is nasty stuff... its mildly corrosive. it will eat gas tank linings, rubber and aluminum if used in excessive ratios.
i was once watching an Indy racing film from the 60's, the driver was in the pits jumping and rolling around on the ground like he had ants in his pants, everybody else was scrambling around him. METH FIRE!!!
meth burns without a flame. you don't see it until you feel it... its BANNED from Indy.
I am a nitpicker for details sorry. Indy cars run 90% methanol. In 2007 they are switching to ethanol.
Old Sep 9, 2006 | 10:43 AM
  #107
evoone's Avatar
Unhappy
ahhh... brainfart. you see, continual exposure to meth can cause nervous system damage.
Old Nov 14, 2006 | 09:18 PM
  #108
thatsMR2u's Avatar
its really easy to recalibrate you TPS with tatrix cables and evoscan- just set your TPS idle to 13.33% while car is running and your golden
Old Nov 26, 2006 | 08:53 AM
  #109
arpad's Avatar
awesome write-up, thank you!!
initial impressions: stalls at red lights and hesitation under WOT gone
can anybody confirm this: "Screw in the plate and you're done. If you installed it correctly, the top of the butterfly valve should open inward to the Intake Manifold side."
the only way I could get it back together was for the bottom to open towards the intake manifold
Old Nov 26, 2006 | 08:59 AM
  #110
arpad's Avatar
does anybody know what the green arrow is pointing to in this picture? I couldn't figure out what its use is... seems to just be two flexible strips of metal with a rubber coating, attached at one end to one of the screws that holds the TPS on.
Attached Thumbnails Throttle body air leak...Pics inside with how to fix!!!-throttlebody.jpg
Old Nov 26, 2006 | 09:18 AM
  #111
EvoTio's Avatar
Lol, those are just metal holders to secure the wires from your sensors. You just open them up, slip in your wires/wiring harness and fold the flexible metal holders in to secure them.
Old Nov 26, 2006 | 09:37 AM
  #112
arpad's Avatar
hehe I considered that, but over-analyzed it and thought there must be a better use.
Old Nov 26, 2006 | 10:47 AM
  #113
nigletsyz's Avatar
there are a couple mistakes as I did the write up a day later but I can't go back in and edit them anymore. I believe you are correct being that the throttle shaft will get turned clockwise when stepping on the accelerator.
Old Nov 28, 2006 | 11:54 AM
  #114
luscious's Avatar
Question
Damn am I glad i found this! I found my throttle shaft was leaking about 6 months ago, and have been living with it thinking the only thing i can do is replace the whole damn TB. I just ordered my seals!
I had 3 injectors leaking air at one time.....but a second time I did a leak check they didnt..
Old Dec 9, 2006 | 11:43 AM
  #115
justchil's Avatar
How exactly do you do this? Are you moving the sensor with ecuscan running and making adjustments til it his 13.33%? Mine was a hair off @ 14.2%.
Oh yeah and definately buy a new TB gasket when you do this. Mine is leaking like crazy now
Update
Set the TPS to 13.3 adjusting it and reading the value on mitsulogger (evoscan alternative).
I used some gasket maker rtv stuff on the tb/intake mani gasket which has it 100% sealed. Now the freaking tb shaft seals are leaking again. It holds boost better than before during a leak test but it's still leaking
The only thing I noticed during the install was the new seals didnt seat as snug as the stockers were... did anyone else notice this? I used the seals from machv.
Old Dec 12, 2006 | 12:48 PM
  #116
justchil's Avatar
bump.. anyone??
I don't think my original leak was coming from the shaft seals lol... but now with the new seals they are leaking Check the post before this one.
Old Dec 12, 2006 | 05:30 PM
  #117
nigletsyz's Avatar
i noticed one of the seals seated better than the other. However, after I installed them, I leak tested the system and both held the pressure fine.
Did you make sure there was no residue from the old seal?
Old Dec 12, 2006 | 06:33 PM
  #118
justchil's Avatar
I'm pretty sure but I could have goofed something up. I'm going to pull it all apart and order another set of seals just in case.
Old Dec 12, 2006 | 08:50 PM
  #119
thatsMR2u's Avatar
sorry i didnt see this before- but seems like you figured it out- its relativly easy to with the car running! much easier than the previous way i did which was measure volts to .068 or whatever- that ended up being off also which registered as 12.78%tps
Update
Old Dec 13, 2006 | 10:28 AM
  #120
EMonz57's Avatar
Wow.. glad I searched this. My CEL keeps coming on and I checked it at the zone and it came up as TPS then today the light went out randomly. It had been going off and on for a while. the driveablity of the car was getting on my nerves too since it is so rough and it acts like it is being vented.
I kept saying It has to be a leak but never did check. of course never would have expected this anyway. This thread may have just saved me from buying a new TPS. I also noticed I hit fuel cut really easy at weird amounts of boost sometimes and weird throttle possition so now im thinking this is all related. BTW a tad under 41K on my 03
for this write up and info
