Throttle body air leak...Pics inside with how to fix!!!
Old Dec 13, 2006 | 05:16 PM
  #121
EvoTio's Avatar
Originally Posted by EMonz57
Wow.. glad I searched this. My CEL keeps coming on and I checked it at the zone and it came up as TPS then today the light went out randomly. It had been going off and on for a while. the driveablity of the car was getting on my nerves too since it is so rough and it acts like it is being vented.
I kept saying It has to be a leak but never did check. of course never would have expected this anyway. This thread may have just saved me from buying a new TPS. I also noticed I hit fuel cut really easy at weird amounts of boost sometimes and weird throttle possition so now im thinking this is all related. BTW a tad under 41K on my 03
for this write up and info
You know that I never got any CEL's nor did I notice any driveability problems when my seals were bad. All I was experiencing was a slightly rough and unstable idle. So you may have other issues with your car. I would definitely do a boost leak test to rule out leaky seals or any other leaks that you may have.
Old Dec 13, 2006 | 06:44 PM
  #122
thatsMR2u's Avatar
hope its just your seals but if its your TPS- im in MA and have an extra for sale hit me up
Old Dec 14, 2006 | 06:29 PM
  #123
mitsuorder's Avatar
You know way before the seals were found to be a fixable problem, right before my IAC motor went out, I had a cel that read "tps malfunction" or something along those lines.
Old Jan 1, 2007 | 06:49 PM
  #124
RedV's Avatar
This is great info, and I'm planning on doing a leak test shortly.
I'm just wondering if there's any differences in building a leak tester for the IX. Is the turbo inlet the same size? Any differences in TB bearing seals?
Old Jan 13, 2007 | 10:19 AM
  #125
turboevo8's Avatar
I got an 05 EVO with less than 6000 miles and it leaks now! I a can't believe it is bad so fast. I kind of wonder if the leak test blew out my gasket? As no one would really know unless they did the test.
Old Jan 14, 2007 | 07:04 AM
  #126
mot's Avatar
mot
yeah my 05 def sticks when i rev high and then the rpms fall VERY slowly i had no idea what it was it didnt do it very often at all then started getting worse
the car is off the road for winter and im thinkin i might just do an aftermaket intake manifold and throttle body because i dont want to have to tear my throttle body apart every 10k
does anyone know if this happens to aftermarket throttle bodies
ive also noticed a lot of the cars in the reads ive read concerning this have been 05s
thinks theres some sort of relationship with the 05s and much worse seals?
Old Mar 13, 2007 | 01:20 PM
  #127
92gsxbaltimore's Avatar
had a sticky throttle in my 92 eclipse a while back and almost died a couple times. Procedure above fixed my issues. Happy boosting!
Old Apr 1, 2007 | 08:15 PM
  #128
Charlie_B's Avatar
Seals on the way!! Cant get over 8 psi on the test right now, and throttle is sticking sometimes. THANKS for the info!
Old Apr 2, 2007 | 05:47 AM
  #129
redevoboy's Avatar
Wow this really opened my eyes! I am deffinately making a boost leak tester tomororw and testing my car, ive just been putting it off! Ill report back here with my findings! Thanks!
Old Apr 12, 2007 | 10:18 AM
  #130
CBRD's Avatar
just had a car come in today with this problem...
cb
Old Apr 12, 2007 | 11:04 AM
  #131
V.8MR's Avatar
I have a thread in ecuflash about throttle hangup and im wondering if this is at all related. I may have to check mine as well!
Old Apr 12, 2007 | 12:37 PM
  #132
arpad's Avatar
Wow I hadn't even thought about the throttle hangup... I had that and the cause had perplexed me for quite a while. I just realized that it hasn't done it since I changed those seals...
Old Apr 12, 2007 | 03:08 PM
  #133
mitsuorder's Avatar
I try to push for this to be taken care of for every car I work on these days.
Old Apr 23, 2007 | 11:24 AM
  #134
TylerO@WORKS's Avatar
As the pioneers of the throttle body upgrades for the EVO, WORKS has been aware of this issue for sometime and has a proper solution (correct style, fitment, and pressure rating) coming this summer.
Old Apr 23, 2007 | 12:54 PM
  #135
justchil's Avatar
Hopefully it will be affordable I've replaced mine going on 3 times and it still leaks
