Throttle body air leak...Pics inside with how to fix!!!
Old Aug 6, 2007 | 08:28 PM
  #181
Lazeum's Avatar
Originally Posted by mikesevo8
Yes - I just saw that link. I will probably order those.
But I was wondering how others have gotten seals from NAPA, when my NAPA guy looked at me like I was
growing a third arm out of the top of my head...
I had the exact same experience... I went to NAPA with the PN#. The guy in front of me has the face of someone whose heard something for the first time... So I walked away.
Then, I ordered the seals to Mach V with a new gasket and asked to have everything mail with a regular mail to lower the cost. The deal with them was just ideal, I've only good comments to give.
Those seals are on my car for over 10 months. So far no problem at all, they still hold boost like OEM seals should have
Old Aug 6, 2007 | 11:02 PM
  #182
mitsuorder's Avatar
Well I've never seen them stocked but I'm looking at the box right here in my hand. It's a light green box, SKF brand oil seal, part# 3930 with "CR 10X14X3 HM4 R" underneath the part#.
Old Aug 7, 2007 | 06:30 AM
  #183
mikesevo8's Avatar
Makes more sense now.
The "CR" is for Chicago Rawhide, which is the supplier NAPA said they use now.
"10X14X3" is the size.
Old Aug 7, 2007 | 09:58 AM
  #184
mitsuorder's Avatar
Cool, I had never asked what the "CR" stood for but knew it had to have something to do with the supplier. Good luck
Old Aug 29, 2007 | 07:11 AM
  #185
I-Dom-In-8's Avatar
How the heck are you guys removing the TPS bolts, Im trying to take them out so i can replace my TPS sensor and the 7mm socket wont even go over the bolt..btw im not taking the Tb off the car, im trying to do it as is,
Old Aug 29, 2007 | 07:17 AM
  #186
Lazeum's Avatar
Remove the TB from the car, it will become much easier
Some hoses on the back side of the TB are a pain to remove but it will make your life much easier.
+ you can clean up the TB easier both side of the butterfly.
Old Aug 29, 2007 | 07:31 AM
  #187
I-Dom-In-8's Avatar
Yeah i was just trying to save the time of taken it all apart, Just gotta go get the TB gasket then and some cleaner....and thanks
Old Aug 29, 2007 | 07:34 AM
  #188
justchil's Avatar
I used a "stubby" phillips screwdriver. Be careful putting them back on.. you can break them pretty easy.
Old Aug 29, 2007 | 07:35 AM
  #189
Lazeum's Avatar
Actually I think, you achieve the oppposite... But that's OK!
...and you're welcome
Old Aug 29, 2007 | 07:48 AM
  #190
Luis@TTP's Avatar
works sells the throttle body shaft seals i installed them on my car when i found it to be leaking thats what it is for sure. when re-installing use a silicone based grease on the seals so it doesnt dry out and happen again.
Old Aug 29, 2007 | 08:14 AM
  #191
stimpy's Avatar
A 7mm socket on a 1/4" ratchet fits just fine, I was playing with the lower bolt last night. I'm pretty sure it is not actually possible to do with the throttle body on the car. To press the old seals out requires some engineering.
-Jon
Old Aug 29, 2007 | 08:52 AM
  #192
mitsuorder's Avatar
Permatex dielectric works great
Old Sep 1, 2007 | 03:54 PM
  #193
I-Dom-In-8's Avatar
Thanks for the write up, Was able to change out my TPS useing this how-to..
Old Dec 16, 2007 | 02:26 PM
  #194
ROGERV's Avatar
I just changed my TB seals with Works. Ran into some small problems but everything went well.
Thanks for the write up.
Old Dec 16, 2007 | 05:42 PM
  #195
kilgoja's Avatar
Originally Posted by TylerO@WORKS
Probably because all the commercially available seals of the correct dimensions are only rated at 7psi.
To get the proper seal made we had to talk to many different manufactures. We are pretty sure that even the factory seals installed by Mitsubishi are the same 7psi rated junk seals
Our custom spec seals are on the way, we should see them this summer some time... We will keep you guys updated.
is this problem just on the viii or the ix as well?...why would mitsu use 7psi seals on a car that boosts 20psi?...are they that stupid?
