Evo's oil change with pics
Old Nov 11, 2006 | 03:02 PM
  #31
Profoxcg's Avatar
Part number 06 EVO IX
my dealership sold me MZ690116 which was a shorter filter which looks just like the one I took off from the car for the first time and bolted on right.
I noticed however that the "FACTORY" filter although it looks the same with the difference of some Japanese writing on the site has a differet part number. - has anyone else noticed this?
Old Nov 11, 2006 | 03:08 PM
  #32
keevo54's Avatar
Different numbers but the same part, at least thats what the parts guy told me. They part they sell has diffferent number than the one from the factory
Old Nov 11, 2006 | 03:39 PM
  #33
Profoxcg's Avatar
yeah i guess so, especially since there werent any jap letters on my US filter?
Old Nov 19, 2006 | 12:29 PM
  #34
kilgoja's Avatar
my mr drain plug is 19mm
Old Nov 19, 2006 | 12:39 PM
  #35
Evoryder's Avatar
19MM on the MR? interesting
Old Nov 19, 2006 | 05:22 PM
  #36
s0lja's Avatar
I see a lot of typos but a very good write-up indeed!!... Propz
Old Nov 23, 2006 | 09:06 AM
  #37
bud_thoj's Avatar
so....there is a taller and shorter oil filter made for the evolutions from mitsu??
Old Nov 23, 2006 | 09:14 AM
  #38
4G63 T's Avatar
Very helpful to me...as i never done oil change before.
Old Nov 23, 2006 | 09:18 AM
  #39
Turbolover's Avatar
Add oil to filter to prevent dry-startup. Other then that and the filter size, good write-up!
Old Dec 12, 2006 | 11:56 AM
  #40
WRC-GO's Avatar
Just changed my 9MR - just curious
as to what the purpose is of the electrical connection on the oil drain plug? It's completely different than the one pictured, has no crush washer, etc. I wonder if it's for the oil pressure gauge? At any rate, I torqued it back fairly lightly (around 15-20 ft/lb) and guess it's ok.
Also, just fyi, the filter number from the factory was different than either of the ones in this thread, but looked just like the smaller model.
Old Jan 3, 2007 | 10:35 AM
  #41
joshesh's Avatar
are the crush washer really necessary to buy new every time you change your oil?
Old Jan 3, 2007 | 05:23 PM
  #42
SRT-TO-EVO's Avatar
Comes with the filter.
Old Jan 4, 2007 | 12:14 AM
  #43
AV8NDOC's Avatar
the crush washer will assure a proper seal with no leaks.
if you reuse one you risk putting another crease in the edge and getting a leak
you can use the old tried-and-true copper crush washers which should be pennies each at your local auto parts store
but, yes, I agree that they should sell you one with the filter at the dealer if you use the MMA part
Old Jan 4, 2007 | 01:44 AM
  #44
SRT-TO-EVO's Avatar
It does come with the filter dude if you buy factory of course (which is what I reccommend, and the only one I would use anyway).
Old Jan 4, 2007 | 01:54 AM
  #45
Yme's Avatar
Yme
Thanks for the write up
