Simple front camber increase
Old Aug 20, 2006 | 12:32 AM
  #31
Bexa20's Avatar
I have a quick question, I spoke with the guy who does the alignments and he told me before I come in to get the eccentric bolts. What is the differece between those bolts and the ones that are already on the car? The suspension is stock and nothing was ever touched, and I want to add some more negative camber for autox events.
Old Aug 20, 2006 | 03:31 AM
  #32
EJEvo's Avatar
The eccentric bolts are supposed to come stock on your '03 Evo. If you have checked and yours aren't eccentric, I'd talk to my dealership's parts guy about getting some. I've never heard an explanation as to why some here claim their bolts aren't eccentric.
Old May 17, 2007 | 10:56 PM
  #33
J8dailo's Avatar
i had my alignment done and my front camber couldn't be adjusted either...but this was done part of training but we ran out of time....
Old Aug 23, 2008 | 12:56 PM
  #34
stockEvoIX's Avatar
Yeah, my driver's side seem to have less negative camber than the right after doing this. Maybe I will loosen both bolts on the strut and re-tighten to see if it's better.
Old Aug 23, 2008 | 05:16 PM
  #35
jebjkey's Avatar
I did this on my MR and then took it in for an alignment. Toe was .5 degrees in on both sides when they hooked everything up. Camber came out to -2.0 and -2.1 and I had them put toe to zero all around. I swapped the camber bolts in conjunction with drilling my stock sway bars. I posted the results here. https://www.evolutionm.net/forums/sh...t=76883&page=3
Old Feb 3, 2010 | 11:14 PM
  #36
Sn0w Man's Avatar
so would this also apply to the 02 lancers as well?.... I just installed new inner and outer tie rods, and went to Firestone to get an alignment.... Dude told me that my camber was off, and i needed new camber bolts for the front left and front right..... (pissed me off by trying to double charge me ($58) for the same SPC kit from O'rileys for $28)..... now I got a set of camber bolts and am wondering if i just throw them on the strut/hub assembly, or do i have to have the arrow a certain way?..... keep in mind im getting an alignment right afterwards, and its 1.5 miles down the road...... Y'all think ill be alright just throwing them on, considering they are gonna have to adjust the camber anyways. im tired right now so if im wording things wrong or not making any sense let me know.
heres pictures of the specs from firestone... yeah i know my passenger side is WAAAYYY off
http://i725.photobucket.com/albums/w...e/SNC00060.jpg
http://i725.photobucket.com/albums/w...e/SNC00059.jpg
Also, since the car is lowered 2" on Sprint springs and GR-2 struts, would i want to set the camber + or - factory specs or just leave it as the factory specs, if so would i do the same as the write-up mentioned by the Op?
thanx guyz
Old Apr 14, 2012 | 06:34 AM
  #37
Pitside's Avatar
Originally Posted by Kyperion
Just a word of warning.
Changing front camber effects toe settings, so be sure to get them checked if you do this. You can seriously effect tire wear if you bump camber like this and do not make a correspnding adjustment (or at least check) of the toe setting.
There are so many things wrong with this how to. I would not suggest this at home. Take it and have it aligned on a machine. Kyperion is exactly right is doesn't take much to really screw up your toe settings and destroy tires.
Old Aug 17, 2013 | 09:38 AM
  #38
sivs's Avatar
if my bolt is facing down what camber around might that be
Old Aug 17, 2013 | 03:45 PM
  #39
cfdfireman1's Avatar
that means somebody F'd up the job. the bolt has a flat spot and only goes in one of two ways.
Old Aug 17, 2013 | 05:41 PM
  #40
sivs's Avatar
thats what I figured. thx
Old Aug 17, 2013 | 06:12 PM
  #41
all is not lost, post #2 in this thread has a good pic of what it should look like. yours is just missing the tab below the bolt. a good alignment shot can work around it.
Old Aug 17, 2013 | 06:45 PM
  #42
sivs's Avatar
tab is there, heres what I mean
arrow is down although its tough to see, but u can see the flat spots are to the left and right not to the tab. I think its near zero camber as seen in the pic. I rub the fronts barely but I think if they would put camber up front I would be ok
Im trying to get these wheels to fit alittle better with no rubs. 18 x 8.75 + 20mm
245/40/18
Attached Thumbnails Simple front camber increase-20130817_212926.jpg   Simple front camber increase-20130817_212128.jpg
Old Aug 17, 2013 | 08:57 PM
  #43
What you can do is back off the nut so the bolt can move out then hammer the tab back in some so the flat on the strut matches the flat on the bolt. It really doesn't matter because once the thing is tight it ain't movin. Get an alignment and make sure the fronts match left to right, that's the important thing. There's plenty of slop in the adjustment bolts to get them the same.
You have to get the car on an alignment rack to see where you're at. Eye-ballin it ain't good enough. When you change the camber it affects the toe and if you don't adjust that then you burn up tires.
MitsuJoe
468
Feb 20, 2016 11:17 AM
EGbeater
Jan 16, 2016 04:14 PM
DangerousDan
04-06 Lancer Ralliart How To Requests / Questions / Tips
Aug 19, 2009 11:47 AM
bbenavitz
Dec 24, 2004 06:01 AM
point&shoot
Sep 21, 2003 05:41 PM
