How-to Perrin 25mm rear swaybar & stout mounts
#32
Bringing this thread to life. im going to be installing my sway bars this weekend and heard from a friend i should tighten end links when car is setting down on all fours as it would be on the road, that way it doesn't mess with the geometry of the car and unwanted stress is this true?
#33
Bringing this back from the dead with one thought on the install.
Getting stock rear endlinks off when they haven't budged in 85k miles is no small task. I found the best way was to disconnect the bottom of the rear shock, stick an impact on the endlink nut and grab the actual shaft of the endlink with vice grips as hard as you can. It took a little bit, but they both eventually gave up and came apart. Using an allen key and a 14mm wrench was hopeless.
Otherwise it wasn't too bad, just the typical fighting with large bolts that have never been removed on a 7 year old car that gets driven during the winter. Took a few hours though. Haven't driven it yet, I'm pooped.
500whp.com
87
May 31, 2016 01:30 PM
FS[MidWest]: (MN) 2006 Evo9 SE - Tarmac Black - $21,999
scheides
For Sale - Cars For Sale
12
Sep 9, 2015 08:37 AM
201Motorsports
Evo 'For Sale' Suspension / Brakes / Handling
Sep 18, 2009 12:11 PM
Jakeg97
Jan 18, 2005 07:35 PM
