My Battery relocation and trunk net [pics]
Old Oct 12, 2007 | 02:34 PM
  #61
TearItUpSports's Avatar
There are two other things you should have with a remote battery setup.
A fuse/circuit breaker, and a battery master kill switch. The switch should either be on the outside, or easy to access from the outside of the car.
Old Jul 9, 2008 | 02:06 PM
  #62
eddieededy's Avatar
Originally Posted by joeymia
if you plan on tracking your car you will most likely not pass tech with that setup.
^ +1
agree, make sure u have it coverd completely ( spill proof!)
i will put mine in the rear right side to balance somewhat the car!
Old Jul 9, 2008 | 03:14 PM
  #63
SophieSleeps's Avatar
Originally Posted by eddieededy
^ +1
I did take my car to a track day and passed tech inspection.
I put in a dry cell battery. No fluid in it.
Old Aug 2, 2008 | 02:44 AM
  #64
Shocky's Avatar
great work
Old Aug 19, 2008 | 08:06 AM
  #65
Redlimit835's Avatar
Originally Posted by SophieSleeps
From the pics it looks like you have 2 holes on the cover, and 2 pretty large holes for the thick guage wire to come in.
aren't you venting into the trunk with those? It doesn't look like it's a sealed box. Is there a gasket of some sort anywhere?
sry just now back reading the thread.... those 2 holes in the lil on my box are the "orgnial" hold downs... this box is actualy made for a very small "racing" battery...... i did some moding to make the biggest CCA batter fit that i could.... if you look back an my pics u can see how tight of a fit it is in there...... and you can see how i moded the factory batt hold down to fit the optima in there..
later
DJ
Old Nov 15, 2008 | 11:29 PM
  #66
francisr362's Avatar
Good advice man, so did u actually put the fusible links in the rear with the batter of just supplied power to the fusible links to the front from the rear with a 0 gauge power cable?
Also how many grounds do u really need?
Old Dec 8, 2008 | 04:46 PM
  #67
chasethorpe5126's Avatar
where a good place to get the wire and circut breaker?
Old Dec 8, 2008 | 05:37 PM
  #68
Summit Racing has a big selection i believe.
Old Jan 3, 2009 | 11:43 PM
  #69
bluemonster2's Avatar
summit racing is a good place i have been researching the best way to do this for a while awesome pics and good description. great how to thread..
Old Jan 6, 2009 | 09:13 PM
  #70
boostedspra's Avatar
I have gotten my battery relocated and I want to know what size (amperage) inline fuse I should run. I know a starter takes a heck of a lot of amps while it is cranking. So what fuse can I use that would be beneficial if the wire ever ground out but I wouldn't be replacing it everytime I go to start my car?
Old Jan 7, 2009 | 06:49 AM
  #71
Normal cranking loads can require 125 to 200 amps or more from the battery depending on engine displacement. Im just not sure what sizes they offer to tell u to run with. I would say something about 250 would be safe.
later
DJ
Old Jan 10, 2009 | 09:06 AM
  #72
hlm's Avatar
hlm
nice thread. I like it when people take there time and do a good job..
Old Jan 8, 2010 | 02:06 PM
  #73
Kdash106's Avatar
so, does the big fuse on the positive terminal in the front needs to be cut and remove to the back connecting to the 0 gauge wire?
Old May 13, 2010 | 10:49 AM
  #74
Dragracer187's Avatar
when you drill a hole in the trunk how do you bolt the battery holder to the sheetmetal, is there easy access from under the car to get a nut on the bolt??? I want to place my battery in the passengerside corner closest to the rear seat.
Old Oct 17, 2010 | 08:58 PM
  #75
There is not access under the car near the back seat. Thats where your rear subframe for your suspension is. Its much easier to put it in one of the corners of your trunk like mine is. The worst that is in your way is your exhaust, and your emissions canister( which is only a few bolts to get out of the way to set up your box)
