02 Cat Delete NEW TO THIS questions
Old Feb 22, 2007 | 04:08 PM
80210's Avatar
Im getting a cat back, and want to also get a downpipe and cat delete.... I've read different thing about o2 ports and also the 02 sensor on the cat delete causing not only check engine issues but also air/fuel issues....
Basically will a downpipe or catback cause any issues with 02?
How or where do I get a test pipe so that this doesnt occur?
Thanks!
Old Feb 22, 2007 | 09:16 PM
80210's Avatar
bump
Old Feb 23, 2007 | 06:23 AM
Q@EvoPowerMods's Avatar
Use the search function at the top of the forums. Key in "CEL Fix"....there is a fix...where you order your exhaust system..ask about it they will explain it to you..."basicly" you want to draw back in the O2 sensor out of the exhaust stream inside the piping. You can do this by adding extensions to the "bung" where the O2 sensor resides. Do the search read the posts, you'll understand it at that point...
Q/ST
Old Feb 23, 2007 | 07:35 AM
80210's Avatar
where are 02 sensors found, testpipe, cat, or dp?
Old Feb 23, 2007 | 07:38 AM
80210's Avatar
In other words, what do I need to do in order to not throw off a cel and maintain all the "stock" diagnostics of the ECU?
Old Feb 23, 2007 | 08:12 AM
EVOpacoIX's Avatar
here: https://www.evolutionm.net/forums/sh...ghlight=fouler it's very easy and cheap. I am running a test pipe with this fix and no SES light!
Old Feb 23, 2007 | 11:10 AM
80210's Avatar
Thank you! so the stock IX Cat does have an 02 port? Also, should I make sure I buy a test pipe with the o2 port?
Do I only hook it up to the testpipe or is there one in the catback or downpipe?
Old Feb 23, 2007 | 11:53 AM
EVOpacoIX's Avatar
the 2nd o2 sensor is on the stock catalytic, there should be a bung for it on the catback, which is where do do the "fix"
Old Feb 23, 2007 | 02:09 PM
80210's Avatar
Is there one or two 02 sensors on the IX's exhaust system? I thought there was one on the stock cat and then also on the stock exhaust?
If its only on the stock cat, then can the 02 wire reach to an aftermarket catback?
Old Feb 23, 2007 | 02:23 PM
EVOpacoIX's Avatar
there are two o2 sensors, one in the o2 housing and one in the catalytic. And yes the wires will reach.
Old Feb 23, 2007 | 04:33 PM
80210's Avatar
great thanks, if I were to get a 02 housing test pipe and my catback has a 02 housing... do I cover one up or what?
Sorry about all the questions but your helping me out so thanks
Old Feb 24, 2007 | 08:11 AM
EVOpacoIX's Avatar
the o2 housing bolts up to the hot side of the turbo, (the 1st sensor goes there) then comes the downpipe, then the test pipe and then the catback. The cat back should have another bung for the 2nd o2 sensor, which will come off the stock catalytic converter.
Old Feb 24, 2007 | 08:15 AM
Evo9"Miss Rose"'s Avatar
Q/ST
+1 thats what i did!!
RiversideMitsu
Jul 28, 2023 09:23 AM
Celica2EVO
12
Nov 6, 2007 05:05 PM
80210
Feb 21, 2007 07:39 PM
EidolaDream
Dec 7, 2004 06:10 PM
Itsmeeeugene
20
Nov 29, 2004 05:47 PM
