Rear o2 sensor question.
Old Dec 2, 2005 | 12:59 PM
RiversideMitsu's Avatar
I was wondering if anyone has ran the stock ecu with out the rear o2 senor pluged in. I might swap a buddy for his cat back exhuast "06 mr" which is setup with the sensor bung off the cat. I have a 05 and I have my downpipe and cat delete, but my cat back hasnt came yet. Im runing at the track this weekend and I was thinking I should use my friends catback exhuast and just not run my rear o2 sensor. I know my closed loop will get out of wack but my open loop under WOT should be fine. I also thought about just droping my cat back and runing downpipe and cat delete only.
Old Dec 2, 2005 | 01:00 PM
SR20DE-T's Avatar
CEL will come one. I will not effect anything. I there to check for cat efficency.
Old Dec 2, 2005 | 01:04 PM
turboDan's Avatar
Not true.The sole purpose of the rear o2 sensor is to monitor the Cat. to see how effectivly it is working,if at all,and has no other purpose.It does not adjust your fuel trims,that is what the pre-cat o2 sensor is for.
OBDII mandated that the cat must be monitored and that was why the rear o2 sensor was added for,to monitor your cat........
Old Dec 2, 2005 | 01:06 PM
mchuang's Avatar
cell will come on..obd 2 is smart and will throw cell car will run like caca..go buy a 02 simulator and you can remove it all you want.
Old Dec 2, 2005 | 01:13 PM
Keep in mind this is for this weekend only. I will have my catback exhuast with the 02 sensor bung in it next week. I just want to run with full exhuast this weekend at the track.
Old Dec 2, 2005 | 01:27 PM
mchuang's Avatar
your car do what you want.. i would get a simulator..only 25 bucks well the one i bought, but from what i understand any time the car throws a cell it will run like caca..obd1 can get away with it
Old Dec 2, 2005 | 01:46 PM
wbresson's Avatar
o2 sim
Old Dec 2, 2005 | 01:48 PM
RazorLab's Avatar
Wrong, the car will not run any differently. Just trips a cell, that's all.
Old Dec 2, 2005 | 01:58 PM
nutrulz's Avatar
So let me get this straight. If I cut the wires to my rear O2 sensor,with an O2 simulator, and replace it with wideband, all will be peachy?
Old Dec 2, 2005 | 02:12 PM
mchuang's Avatar
Well maybe I am thinking in obd2 honda terms then..that is what i use to own..anytime you remove cat cell comes on for second 02 and car ran like crap.. that is why everyone was always converting over to obd1
Old Dec 2, 2005 | 02:37 PM
I just unpluged it and test drove it and let it idle. Only thing I notice is the check engine light no idle problems what so ever. Under WOT the o2 sensor is ignored anyways so I dont think it will affect anything at the track.
Old Dec 2, 2005 | 02:39 PM
nutrulz's Avatar
Is that with or with out an 02 simulator?
Old Dec 2, 2005 | 02:53 PM
05SilverEvoVIII's Avatar
Not always true it is really a 50/50 thing, some of our cars today run well with the cell on in fact better due to being in limp mode which is your normal driving skills, and others drive better when you have a 02 sim just depends on what luck you got!
Old Jul 27, 2023 | 11:13 PM
BabyLancerFlex's Avatar
does this hold true to the rear o2 sensor on a regular lancer es?
Old Jul 28, 2023 | 09:23 AM
varv's Avatar
Yes. And if you have any doubts just get sim. You need to remove o2 sensor once anyways.
X2jesse1x
Oct 29, 2017 03:23 PM
Chuckdimpala
10
Jan 27, 2015 07:28 PM
cool_g_83
27
Jan 19, 2010 11:17 AM
jerrymldz
12
Oct 13, 2007 08:22 PM
80210
12
Feb 24, 2007 08:15 AM
