Valve Cover Painting...
Old Mar 27, 2007 | 09:43 AM
ElectricEvoIX's Avatar
Has anyone painted their valve cover a different color and if so what was the process. Or does anyone know of a write that can explain the process. Thanks again
Old Mar 27, 2007 | 10:29 AM
Hannibal Smith's Avatar
I was considering doing this myself and changing the color of my valve cover. I'm guessing that surface prep is the key to a good, durable job. I will be doing the same steps as I did with my rims: sand with 320 grit paper, wipe down with surface prep from NAPA, prime, and then paint desired color. I'm going to see what colors VHT offers. IMHO VHT is the best engine paint on the market. I'll post up pics when the job is done.
Old Mar 27, 2007 | 11:06 AM
OZrallyracer's Avatar
I'm somewhat intrested in this as well...
Old Mar 27, 2007 | 11:10 AM
RenoEvo's Avatar
Mine is custom powdercoated gunmetal/black with a textured surface. Its fckn sick!
I'll try to get some pics soon!
Old Mar 27, 2007 | 11:13 AM
Apex Racer's Avatar
I did this a long time ago. Just remove your valve cover, cover your head with a clean trash bag let the oil from the valve cover drip into a catch can for awhile. Then sand down the entire cover, clean it up with some paint prep. Once its ready for paint hit it with 3 base coats of primer. I used white engine primer to withsatand the heat, then let it drie for 15 minutes or so. Then hit it with as many color coats as you need to achieve your desired effect. Then finish it off with 2 to 3 coats of clear. I used high heat clear for this aswell. Mine turned out very good IMO. The only hiccups were the valve cover seal broke ( just fixed it with some RV sealant ) and when I got my clutch replaced they scratched the hell out of it, so now I am getting ready to redo it. I can post some pics later if you like.
Old Mar 27, 2007 | 11:36 AM
goosey2099's Avatar
Please post some pics, I've had mine powder coated but now i got a new one and i need to do this again.
Old Mar 27, 2007 | 12:19 PM
MitsuJoe's Avatar
Your powdercoat did not hold up?
Old Mar 27, 2007 | 12:30 PM
ThunderOZ's Avatar
I want to see this...
so you need engine paint primer, base coat, and clear coat?
Old Mar 27, 2007 | 12:37 PM
goosey2099's Avatar
My valvecover right now is powdercoated, but the new one is used and looks like **** so i want to paint it.
Old Mar 27, 2007 | 12:40 PM
hksevoix's Avatar
can anyone post pics of their custom valve covers? sounds like an idea
Old Mar 27, 2007 | 12:43 PM
evo@24psi's Avatar
Heres mine. Powdercoated as close to BBY as your goina get.
Old Mar 27, 2007 | 12:45 PM
evo@24psi's Avatar
Here's one little closer
Old Mar 27, 2007 | 12:46 PM
Ultimate CC's Avatar
we have done several at our shop here...its about 150-200 for engine bay kit including doing icpipes and intake...
Old Mar 27, 2007 | 01:01 PM
ThunderOZ's Avatar
What's with the hair net on your filter?
Old Mar 27, 2007 | 05:56 PM
CBRD's Avatar
here ya go
aircraft quality paint remover...
primer and some high temp is what we used..
id recommend stripping it and having a bodyshop paint it!
cb
