Replacing EVO 8 oil pressure switch/sensor please help
Old Jan 27, 2011 | 06:57 PM
wizzo 8's Avatar
Nice! Thanks for the info
Old Sep 11, 2011 | 12:03 PM
DREVO978's Avatar
autozone actually carrries the socket for the oil pressure sensor.. just grabbed mine today to do mine.. it was $10..
Old Sep 11, 2011 | 01:04 PM
rhd-jon's Avatar
my advice to anyone is to buy the oem sensor autozone one sucks ***
Old Apr 14, 2015 | 01:05 PM
GOODWISCO's Avatar
Oil light issue
I have been experiencing the same issue with my oil light but is a little different. I have an 05 Evo 8 Gsr. My oil light started off flickering when i was at idle and would go away once i snapped the throttle. It now has gotten to the point where it stays on permanently. After it started flickering it would stay on until i went past 3,500 rpms. Now it stays on regardless of my Rpm range. Has anyone else had this issue. The car still runs great and i havent noticed a change in the driveability. My car has either the original sensor or aftermarket sensor but has at least 5 years of use on it and the car itself has 122,000 miles. I also noticed once the oil light came on my aftermarket oil temp pillar gauge would not read a temperature but would still light up like it works. Any thoughts???
Old Nov 5, 2015 | 05:59 AM
Rags600whpplus's Avatar
Don't use Teflon tape it will leak over time. Oil eats through it. Use RTV instead I know from experience.
Old Nov 8, 2015 | 04:48 PM
barneyb's Avatar
I've worked on cars for 59 years, have used teflon tape since its invention and have never experienced this. You do have to be careful with teflon tape in this use; you don't want it adrift in the oiling circuit.
Teflon is used on nonstick frying pans and what is the definition of frying?
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
ileakoil_mr
Sep 10, 2017 07:30 PM
fireroasted
May 25, 2016 05:30 AM
05EV08
Apr 30, 2016 09:50 AM
2010EVOGSR
Apr 11, 2016 07:05 AM
