spring removeall/install help!
Old Jul 16, 2008 | 12:48 PM
pjb00stin's Avatar
hey guys
when i take off my springs,and install my tanabe gf210's,do i need to cut the bumpstops?can anyone show me where to cut them?and is a spring comressor necessary to remove the springs?
Old Jul 16, 2008 | 12:49 PM
lexat20's Avatar
You definitely want to use a spring compressor or something of the like, unless you don't mind loosing a limb.
Old Jul 16, 2008 | 01:21 PM
pjb00stin's Avatar
what is the bumpstop that i have to cut?
Old Jul 16, 2008 | 01:27 PM
TIBOevo's Avatar
wtf cut the bumpstops?. hell no. you just take the strut out of the car and undo the bolt at the top"be carefull the spring might shoot off as soon as the nut comes off", pull out the old spring and drop in the tanabe's. i just use my body weight to push down on the spring to compress it and then have someone help u get the nut started at the top. then torque the nut at the top with the specs given and everything else to put the strut assembly back in. its easy, i lowered my car in 30min. with air tools using the tanabe gf210. safety first and good luck!.
Old Jul 16, 2008 | 01:34 PM
pjb00stin's Avatar
no air tools=(
http://evomoto.com/tech_info.php?tPa...8ddaddf8959c78
in one of the steps he said if they dont give you bumpstops it might be necessary to cut the bumpstops?
Old Jul 16, 2008 | 02:07 PM
rcheung's Avatar
Originally Posted by pjb00stin
no air tools=(
No air tools only for the top strut nut. The rest is fair game.
Old Jul 16, 2008 | 02:14 PM
CaliMR's Avatar
You can rent the spring compressor from Kragen, or your local public library might have one in the tools department. Yes, some libraries do have tools you can check out.
Old Jul 16, 2008 | 11:32 PM
pjb00stin's Avatar
ayite i'll check that out.thanks bro
LRM1981
Apr 13, 2011 08:27 PM
BriK
Apr 15, 2010 10:08 AM
gatzaraki
37
Sep 17, 2007 10:48 PM
lancer08
19
Aug 23, 2007 02:52 PM
Babblingsponge
Aug 14, 2003 12:17 PM
