Boost guage question
Old Dec 15, 2008 | 03:19 PM
Casper.'s Avatar
Installed it today, everything went smooth. But i would like to know ir something is wrong with teh guage or not. My vac is 15 at idle and im only boosting 10 psi right now. No kinks in the lines and the car feels slow. Just wondering if this is around hte right vac, because other evos are at like 20 ish at idle, dunno just wondering.
Thanks guys, 4wstuning is going to tune the car, but its ***** slow right now, any ideas? And the clutch needs an adjustment bad, car runs like crud between shifts, its very rough and whe ni punch it and shift , the diff sounds like its gunng jump out of the car
Old Dec 15, 2008 | 03:24 PM
btownsoccer22's Avatar
do you mean like 15 psi or the 15hg thing or w/e it's called because mine is at 15hg(correct?) but i get full boost
Old Dec 15, 2008 | 03:28 PM
Casper.'s Avatar
15 hg yes my bad......but i only boost 10 psi..i have a boost leak or the dynoflash tune is totally DETUNED
Old Dec 15, 2008 | 03:32 PM
Kdash106's Avatar
well.. do you have a boost controller? the tune shoudn't effect the PSI i think. it's either boost leak or if u have boost controller, crank it up a little.
Old Dec 15, 2008 | 03:33 PM
Bom's Evo's Avatar
When your boosting the needle should be above the 0 Positive pressure.
When your just idling it'll be pulling vacuum in inches hg or whatever the scale is.
Your vacuum can change from vacuum/boost leaks and different cams change your vacuum too. Do you have upgraded cams?
Take care of your 9, man. Get it fixed by someone who knows what they are doing. You want it running right first, then get it tuned right. After that you will know if anything is wrong the next time.
Old Dec 15, 2008 | 03:35 PM
Bom's Evo's Avatar
Check all your hoses from the intercooler to the throttle body and the intercooler to the turbo outlet. Also check your diverter valve hoses and intake tube. Make sure all the clamps are tight.
Old Dec 15, 2008 | 03:41 PM
Casper.'s Avatar
I will thanks. And no car is stock. Well 4wstuning (Tamer) logged the car and was seeing 14 psi last week. So I dunno what to think until I go back and we figure something out.
ron2003
Aug 18, 2011 10:02 PM
DarksideEng
18
Jan 10, 2006 03:32 PM
bigfishs
Sep 16, 2005 09:47 AM
Go_Lancer_Go
Lancer Aftermarket Forced Induction Tech
46
Sep 5, 2005 07:37 AM
djmikeymike
Jun 12, 2005 04:52 PM
