stripped bolt and nut on hotside,
Old Dec 23, 2008 | 10:54 PM
pjb00stin's Avatar
hey guys,
i was isntalling my titek o2 housing tonite.When i was removing the bolts,one of them was badly stripped.So now i have to get a replacement bolt,but what should i do for the hole that the bolt goes into?
also one of the nuts was stripped so i'll be replacing that and the 'threaded shaft' that it screws onto.will that just screw off?thank you
pj
Old Dec 23, 2008 | 11:13 PM
evo@24psi's Avatar
Yeah u just need to get a stud remover.
Old Dec 24, 2008 | 08:48 AM
pjb00stin's Avatar
how do i re-thread the hole?using a tap?
Old Dec 24, 2008 | 05:22 PM
evo@24psi's Avatar
Yeah, Hopefully it can be retapped. I just had to actually go get some of this done of the 10.5 hotside i just sold. Best thing to do is just call a shop or to and ask if they can do it. Or if you have a machining shop near you that would be even better. I got my stud, not drilled, but welded out and it was only $20. Goodluck man!
rsgjr1970
Aug 25, 2020 10:44 AM
nor11384
16
Feb 26, 2016 09:00 PM
fast08
Apr 18, 2012 06:36 PM
ChrisGST
Apr 26, 2010 01:04 AM
J Yim
Aug 10, 2009 07:21 PM
