HOW TO: Install front rotors
Old Apr 18, 2011 | 10:28 AM
vegas702evo's Avatar
Do I need to take the cap off the brake fluid reservoir when Im pushing the pistons back when re-installing the pads?
Old Apr 20, 2011 | 11:54 AM
TSiAWD666's Avatar
Yes.
Old Apr 21, 2011 | 09:12 AM
bryan0's Avatar
Originally Posted by sleeper-s
I'm gonna do this on my car soon and it looks easy enough... I'm changing the rear rotors out, do I need to do anything special with the e-brake???
No, just release the e-brake (put down the handle) when you try to slide the rotors off and on. If you don't then the shoes inside will be pressing outward on the rotor and it will be near impossible.
Old Apr 21, 2011 | 09:41 AM
fostytou's Avatar
EvoM Community Team
Also, MAKE SURE to pump the brakes and return the pads to the rotor surface before moving the car anywhere... if not you will idle your way right into something!
Old Apr 21, 2011 | 10:34 AM
dastallion951's Avatar
forgot to add matt, if your old rotors are rusted onto the hubs, just get a rubber mallet and tap on the outside of the rotor couple good taps should loosen it up...to reinstall the pads like u said caliper on first, then lube up to the two pins that hold the brake pads on, makin sure that no extra brake pad grease gets on brake pad lining or rotor....other then that good job on the post man
Old Sep 21, 2011 | 03:43 PM
wasFWDnowAWD's Avatar
just a FYI, i followed this partially to begin my REAR rotors and pads and was an idiot and assumed the rear torque spec would be 80ft lbs too. well sure enough i over torqued my caliper bolts and now my caliper is stripped (not the actual bolt, but the caliper themselves). after further research it was suppose to be 40ft lbs for the rear caliper bolts.
now i need to find a way to tap them out or look at possibly thread insert repair kit...
Old Dec 9, 2011 | 06:54 PM
.50 Cal Cow's Avatar
Anyone have any issues where a caliper bolt just doesn't want to loosen? I got the passenger caliper off and rotor changed easily but once I got to the driver side the bottom bolt just doesn't want to turn.
Had to break all bolts loose with a 1/2" breaker bar but for some reason the bottom bolt won't rotate without a stupid amount of force. Got it turn with the breaker bar to a point after several real hard turns but now it doesn't want to move anymore.
Going to try an impact wrench tomorrow but anyone else have this issue?
Old Nov 23, 2012 | 03:15 PM
benihana242's Avatar
What brake fluids do you guys recommend for daily work?
Old Apr 26, 2014 | 11:38 AM
redcat's Avatar
Originally Posted by keath
I am assuming the e brake has to be off for you to take the calipers off.
Yes. Took me a few minutes for me to figure out why the rear rotor didn't pop right off like the fronts. D'oh!
Old Aug 16, 2014 | 08:46 AM
krazirob's Avatar
ughhh rusty hub........i resorted to some WD40 since the lines, rotors and pads are all getting changed out......now we wait for lube to soak.....LOL
Old Dec 13, 2016 | 09:38 AM
fuzzycuffs's Avatar
Anyone with a writeup for the rear rotors? Or is the process the same?
Going to do all 4 plus pads next week.
Old Dec 13, 2016 | 10:21 AM
Heres a EVOX how-to which is the same as ours. This should help
https://www.evolutionm.net/forums/ev...placement.html
Old Dec 19, 2016 | 03:54 AM
redcat's Avatar
Here's a tip . . . Make sure your parking brake is not on. Ask me how I found this out.
I did one of those head slaps when I saw the rubber plug (I assume the plug is there for adjusting the parking brake without removing rotor) on the rear passenger rotor after tugging unsuccessfully on the rotor for 5 minutes.
o-townFLA
Sep 26, 2017 06:38 PM
o-townFLA
Nov 23, 2015 09:18 AM
o-townFLA
Nov 15, 2015 10:17 PM
o-townFLA
Nov 12, 2013 10:08 AM
o-townFLA
Jacks Transmissions
12
Oct 21, 2013 11:21 AM
