Fuse question
Old Apr 6, 2009 | 07:07 AM
joon82's Avatar
Fuse question
Does evo have fuse for passenger side rear light?
I was messing with wires(to tab my gauges) and blew some fuses.
I took out and looked for blown fuses under dash panel. Havent looked at under hood fuses.
fyi I was tapping 12v from dim control.
Found fuse for cig 12v source but cant not find following.
My cig lighter light
climate control light is not working
Dash panel stays dim(not bright) when I turn on headlight
Rear passenger side light is not working(red headlight/break light works)
Old May 17, 2009 | 06:50 PM
chiminican's Avatar
i have the SAME PROBLEM!! how did you fix it????
Old Jun 3, 2009 | 02:56 PM
TTVR-4's Avatar
cig lighter fuse is under the center shift console from my memory..
if you flip your fuse box cover under your hood it has pics and numbers of all your fuses..
climate control lights looks like #22
from my understanding your saying ur rear passanger side running light is out.. passanger side rear running light is #20...
its a 7.5 right next to the ecu fuses under the hood fuse box
SatsuMX
Lancer Troubleshooting
Feb 22, 2016 08:38 AM
Megaapple31
Mar 31, 2013 12:53 PM
wmcorcor
Jun 3, 2009 09:58 AM
silverEVO8
Dec 1, 2005 09:38 AM
shiftdsm E
Aug 4, 2005 11:29 PM
