Prosport Mechanical Boost Gauge
Old Oct 26, 2009 | 05:04 PM
4G63kevin's Avatar
I was wondering what I need to do to install the Prosport Mech boost gauge correctly with my existing MR gauge package. Does the Prosport hook up directly with my existing boost/vac line? What do I use or need to power the lights for the Prosport gauge? What else do I need to do? Thanks!
Old Oct 26, 2009 | 05:35 PM
Svendiesel's Avatar
I have the electric peak/warn boost gauge from prosport, but yes you can use the oem boost line. Does your gauge have the capability of being wired for different color options, like white for day or amber for night, or is it just locked on one color?
Old Oct 26, 2009 | 07:17 PM
4G63kevin's Avatar
Yes, you can switch the colors on the gauge. Do I have to splice any wires of the oem gauge wires?
Old Oct 26, 2009 | 08:57 PM
hang187's Avatar
I just got my prosport boost gauge installed. to power the gauge if you dont want to splice, buy an "add a circuit" and plug it into any fuse behind coin compartment (ignition on). I used the power mirrors. or splice into the cig lighter wire (brown). splice into parking light or headlight switch to make it blue. otherwise it'll be amber.
Old Oct 26, 2009 | 08:59 PM
4G63kevin's Avatar
^ Which is the easiest way that you'd recommened?
Old Oct 26, 2009 | 11:25 PM
hang187's Avatar
i'd recommened use "add a circuit", no splice at all. just add longer wire if needed, then crimp and thats it. you can always remove it, its like plug n play.
Old Oct 27, 2009 | 04:06 PM
4G63kevin's Avatar
Thanks for the help! Can someone post pictures? I need pictures. I get quite paranoid if I dont see pictures. haha ;P
Old Oct 27, 2009 | 07:39 PM
hang187's Avatar
plug it into an ignition on accessory fuse (power mirrors), it now becomes two fuses. crimp the red wire from the boost gauge onto the other end of this "add a circuit". I used a 3 amp fuse, dont forget to plug in the 7.5 amp fuse for the power mirrors (or whichever one you took out).
http://store.42draftdesigns.com/asse...-a-circuit.jpg
Old Oct 27, 2009 | 09:05 PM
4G63kevin's Avatar
Thanks! I will do so. I appreciate your help! ;D
Old May 4, 2010 | 11:34 AM
fugiwara's Avatar
there is easier way doing it, you have MR everything is prewired for you, these people don't have MR so they tell you to use other power source. check the pm i sent you, I just installed the Prosport mechanical boost gauge in my MR, it's so easy and I love the gauge.
Old May 4, 2010 | 01:48 PM
fugiwara's Avatar
He has a MR, it comes with boost guague, oil temp and volt gauge, he just need to use the wire behind stock gauge, no need to follow your direction.
Old May 4, 2010 | 01:49 PM
fugiwara's Avatar
FYI Prosport mechanical can be wired different color option!!!
Old Aug 6, 2012 | 03:07 PM
silversoul's Avatar
Could you PM me how to do this? I had a Prosport electrical boost gauge as well. Thanks!
murderedout
Feb 23, 2016 08:25 PM
S2K2EVO
Apr 18, 2012 03:37 PM
breeze17
Mar 26, 2012 09:00 PM
bellorz
Apr 24, 2011 07:53 AM
xxNosTankxx
12
Aug 14, 2007 01:37 PM
