Fog lamps on w/ parking lights?
Old Nov 5, 2003 | 06:55 PM
jemm's Avatar
UK Evo 8:
Attached Thumbnails Fog lamps on w/ parking lights?-jdm8fogcir.gif
Old Nov 5, 2003 | 07:00 PM
jemm's Avatar
Originally posted by strat
I just pulled the UK Evo VIII schematics for the fog light (and in this case they do call it that) and it is identical to the US. The diagram is not the same, but the wiring is.... Pin 1 from the ECU controls a relay.
heh, i posted the diagram at the same time you posted. Great minds think alike Thanks for your help in finding an answer for this variance.
Old Nov 6, 2003 | 05:31 AM
jemm's Avatar
Here is the front ecu from my car in case you guys wanted to compare the part # with yours...
(pic blurry)
Attached Thumbnails Fog lamps on w/ parking lights?-frontecue7.jpg
Old Mar 7, 2006 | 09:37 PM
trinydex's Avatar
THESE INSTRUCTIONS ARE ONLY FOR AN 05 TYPE FUSE BOX
Basically you take a thin wire, I used 24 gauge, stuff one end of it on the bottom right corner connector of the foglight relay, and stuff the other end of it into the 6th hole from the left on the bottom row of the headlight relay box connector.
These pics show you the detail:
http://www.blak94gsx.com/pics/evofog...d/DCP_2748.JPG
NOW SOMEONE PLEASE FIND OUT HOW TO DO IT FOR AN 04 TYPE FUSE BOX
Old Mar 25, 2006 | 12:25 PM
BaLListic_EVO's Avatar
anyone ever figure this out???
Old Mar 25, 2006 | 11:56 PM
trinydex's Avatar
i posted in like 3 different threads about this... giving hte same info... i made my own thread asking the question... there is just no interest aparently...
Old Mar 26, 2006 | 06:47 PM
so with this mod is the button still functional or do they just stay on??? wondering if its worth my effort to try to figure it out for the 03-04 box
Old Mar 27, 2006 | 02:34 AM
trinydex's Avatar
they turn on and off with the headlights (lowbeam). it effectively shorts out hte fog circuit by taking either the ground or the power from the headlight circuit. the foglight uses a relay which then hits up the software in the front ecu. this is why there's no other way to jerry rig it to stay on, unless you rewrite the front ecu somehow. but even then i think it's a hardprinted circuit board.
Old Aug 25, 2006 | 08:59 AM
timmiii's Avatar
Is it possible to swap the USDM front ecu with a JDM front ecu?
Old Sep 26, 2006 | 02:14 PM
diablo2184's Avatar
Will this work for the 06 IX? Or has anyone figured this out yet?
Old Jan 11, 2007 | 09:45 PM
raiceboi697's Avatar
has anyone tried a simple relay switch? like the aircraft style one with the red covers? i figure that should work.
Old Jan 25, 2007 | 06:35 PM
2006MRevo's Avatar
here's a link to when i did it to my car Parking Lights and Fogs
Kevvsworld
Jul 9, 2021 09:29 PM
4G63_Crazy
Jul 7, 2017 07:42 PM
Raptord
Jun 5, 2016 07:11 PM
Chris725
Mar 4, 2016 07:11 PM
russ72
Feb 16, 2016 05:25 AM
