HKS Turbo Timer Type 1 on Evo8
HKS Turbo Timer Type 1 on Evo8 problem
Installed the timer w/harness via the thread in the how-to forum and it was a simple install
Timer is sitting above my steering wheel at the moment, speed/rpm wires are hooked up, and the wire to the parking brake is also hooked up. The ground is on a solid grounding point.
Driving down the road I can see that the RPM is spot on and the mph/kph are spot on.
I set up the timer to be on Auto but every time i turn the car off it just turns off.. So i turned Auto off and set manual mode to 1.5min and it still just turns off.
any help is appreciated
thanks
thanks
I spliced the blue w/red stripe that is the single wire coming from the parking brake switch towards a bundle. It may have not spliced completely so I'm going to check that but its 3am Ill check it in the morning
Thanks
Something weird happened...
Drove to a gas station, got gas, went to start car and i guess i didn't have the clutch all the way in but nothing happened so i immediately turned the key back and tried again... the turbo timer started counting down, I started the car then turned it off and it worked "kept the car running" I then set the Ebrake down and it turned off like its supposed to.
I think there is something with my ignition or I dont know
It is still not working but it did work that one time "I have not been able to replicate"
RoBear
35
Jun 2, 2007 10:13 PM
