Headlight Adjustment
Old Apr 15, 2006 | 07:33 PM
  #76
dingleberries's Avatar
Does anyone know if this works with the IX?
Old Jun 14, 2006 | 05:57 AM
  #77
fusionchicken's Avatar
will try it out myself tonight and let u know how it goes
Old Jun 17, 2006 | 10:20 AM
  #78
Girlie's Avatar
I am really confuse now. I have a IX MR, and I turned the headlights on and marked the wall where the low beams are stock setting 0. I then turned the setting to 4 and raised the beams up to where they where stock at 0. I did this by using a 10mm socket on a ratchet turning the nut between the highbeam and foglights. From what I can tell the High beams moved as well (looked as if the plastic nut thing turned in cunjuction with the nut the socket was on).
Before anyone flames, I did it this way so on a windy road at night I can turn them up via the cockpit switch, normal city driving turn them down.
Girlie
Old Jun 25, 2006 | 09:48 AM
  #79
555R's Avatar
Post year and model for adjustment directions
obviously there are more than one way to adjust the low beams for each car
we need a chart for each model and year
I have an 06 MR and need to adjust slightly as i kept my drop almost level
but its a bit low still
we need to post results
Old Jun 25, 2006 | 06:50 PM
  #80
555R's Avatar
I just looked
mine too are covered with that plate
so what do I do now?
Old Jun 25, 2006 | 08:40 PM
  #81
BaLListic_EVO's Avatar
after wondering about this i decided to take mine out... the adjustment that is @ the rear of the high beams has a cable that jumps over to the low beams and adjust them. The adjustment behind the high beam adjust the hid....
Old Jun 27, 2006 | 08:04 AM
  #82
555R's Avatar
post a good picture of waht you are talking about...please
Old Jun 27, 2006 | 10:49 AM
  #83
555R's Avatar
IX MR adjustment
5 minute job if that
use the 10mm plastic nut
it will adjust everything ccw raises
cw lowers
you can do it headlights on in the accesory position and the adjusters dont freak outhope that helps anyone
Old Jun 27, 2006 | 11:17 AM
  #84
Kronik's Avatar
I need to do this mod tonight. I have an 05 EVO VIII with HIDS. Hopefully I don't run into the problems a few of us have.
Old Jun 27, 2006 | 05:56 PM
  #85
heSOshAdy's Avatar
Okay, call me crazy but I am turning the exact bolt in the picture N00dle has provided, and it seems like the only thing that it adjusts are the high beams! The HIDS are not moving at all.
What am I missing out here? Is there another bolt next to it that I should be looking for?
Any info would def help! Thanks.
Old Jun 27, 2006 | 06:24 PM
  #86
555R's Avatar
my 06 MR i adjusted the plastic 10mm nut
not even a few turns unlike everyone else
adjusted it to where i wanted it
i dont know what to tell you
Old Jun 27, 2006 | 06:45 PM
  #87
heSOshAdy's Avatar
Okay from pages of pages of reading I think I figured out why only the High Beams are moving. It seems as if the "Black Plastic Gear" is stripped. So now I guess I have to turn them manually.
What is the easiest way to turn this piece manually. I know these gears are made of plastic and are very sensitive? Any suggestions?
Old Aug 10, 2006 | 01:39 PM
  #88
aznxdragon30's Avatar
Mine is stripped also, did you find an easier way?
Old Aug 10, 2006 | 03:10 PM
  #89
Shinobi's Avatar
I tried this and it didnt work, im going to go cry in the corner. I am just going to take the lights out, smoke em and adjust them then. Screw this trying to do it with them in the car because I can't seem to find anything that adjusts any dang thing!
Old Aug 10, 2006 | 03:13 PM
  #90
yea i craked away on mine and didnt adjust..
