Loud stock BOV?
Old Jan 5, 2004 | 01:48 AM
upjess's Avatar
Question Loud stock BOV?
After installation of an AEM short ram intake system I have noticed that the stock BOV became EXTREMELY loud...is this normal? I realize that with an open air intake you should be able to hear the BOV...but I was not aware that there would be such a dramatic difference, so I am just wondering if this is common or a cause for concern? Any information you could give me would be appreciated!!
Old Jan 5, 2004 | 12:51 PM
Schmitty's Avatar
This is normal. The turbo whine becomes much more noticable as well. If you don't have an intake and want the loud BOV and turbo whine, you can just ride around with the top of the airbox off. Tho, this has its obvious risks. I haven't had mine on since i bought the car, no problems. Ghetto, yes. But FREE.
Old Jan 5, 2004 | 08:11 PM
upjess's Avatar
Yea, I knew it was going to make that psssssh... sound but didn't think it was going to sound like the car was breathing Thanks for the reply I feel better.
Old Jan 5, 2004 | 08:13 PM
tweakdsm's Avatar
it is normal..
Old Jan 5, 2004 | 08:19 PM
onet0nsoup's Avatar
yup...wit a hks intake...the bov is pretty loud
Old Jan 5, 2004 | 08:34 PM
eevoo's Avatar
That's the coolest thing about an intake man, all the sweet music!
Old Jan 5, 2004 | 08:48 PM
Schmitty's Avatar
And thats pretty much an intake is good for.
Old Jan 5, 2004 | 10:04 PM
upjess's Avatar
You don't think the steel inlete pipe has better flow than the stock ribbed one?
Old Jan 5, 2004 | 10:08 PM
Schmitty's Avatar
Tests have shown that the stock intake does just as good as an aftermarket intake. The best bang for your buck is just drop an K&N filter in the stock box. The aftermarket intake basically makes the turbo and BOV sound louder....and possible DECREASES performance. For pete's sake, look at the design for the stock airbox....can you get any better? Its almost ram-air with the design. Sure the stock filter is restrictive, but drop a K&N in there (which have been proven to give 8-10whp alone) and you are set.
Personally, the only time I have seen a need for an aftermarket cone-type filter is in super high-performance applications....otherwise the stock airbox is more than sufficient.
Old Jan 6, 2004 | 03:51 AM
Bom's Evo's Avatar
a drop in k&N is perfectly fine.
if you feel u need more flow get the drop in HKS foam filter.
Old Jan 16, 2004 | 10:10 AM
caymandiver75's Avatar
Where did you get the 8-10hp improvement numbers from with just a dropin K&N air filter? Also you guys that run with out the filter lid on, how are you guys securing it so that it doesn't move around. Sounds like a bad idea for long term use.
KillaYayo
Apr 21, 2017 11:03 PM
Bergen Automotive
12
Oct 19, 2010 05:23 PM
vtat9000
10
Jul 26, 2007 06:03 AM
RalliArtEvoVIII
May 8, 2005 07:15 PM
gh0stch1ld
Apr 27, 2005 12:53 PM
