Not Removing Exhaust Manifold when Installing EGT Probe
I used the "car idleing" procedure on my EGT. Even though most of the bits blew out, a couple were in the turbo rattleing around.
I boosted to max and they were gone. I still wasn't happy with hearing them in there.
Originally posted by SinCityEvo
I don't know. My tuner shop recommends (insists) taking off the maifold to do it. They will not do the install otherwise. I will hold off on this. Maybe I will do the downpipe and do a temp correction?
Might as well do an oil change at the same time.
i definatly wouldnt do it with the manifold still on the car....that clinking sound u hear it the peices banging around in your turbo...scratching the inside...ill take the extra time and just remove it
Do you guys think tapping the downpipe right at the top by the flange would give much different readings as opposed to the manifold? I heard some 300 or so degrees, but it would save me a hell of a lot of money and I can do it myself. You can get a basline at the downpipe and add the difference? Won't the temp rise and fall be linear so the correction factor would work? Who knows.
not sure if it applies to the evo or not but on a volvo 850 turbo, the egt should read around 800-1000 after its warmed up and you are crusing
cruising at 65mph on the highway you should see right around 1200...pushing boost you should go past 1400 otherwise you are running lean and now you have an "official" excuse to buy bigger injectors or some kind of fuel management system or upgrade your ECU program
best of luck
best of luck
best of luck
best of luck
prowakeskater
Jul 7, 2011 12:38 PM
EvoDan2004
51
Mar 18, 2007 03:08 PM
silverEVO8
31
Jun 14, 2003 07:42 PM
