ticking after cam install
Old Feb 21, 2004 | 05:10 PM
arpad's Avatar
Hi all,
I had 264/272 cams installed about 1500 miles ago, and was told that the ticking should go away soon. Should it have gone away by now? Does something need adjusted?
Thanks
Old Feb 21, 2004 | 06:01 PM
gunzo's Avatar
the valve tick thingy .. go do the rev to 3000rpms thingy to stop the tick ..
I'll get the specific instructions ..
Old Feb 21, 2004 | 06:34 PM
Quickshift's Avatar
No the ticking will always be there due to the high profile of the cam lobes . How loud is your ticking? is it very loud or not bad. Cause most evos with aftermarket cams will tick and it is normal. **** I tick and I still have my stock cams in for now.
Old Feb 21, 2004 | 08:21 PM
arpad's Avatar
gunzo: Valve tick thingy? Can't find any mention of it on the forums...
Quickshift: It's pretty loud when it's warming up, then after it's fully warmed up it usually disappears... Your stock cams tick? Wierd...
Old Feb 21, 2004 | 08:45 PM
Quickshift's Avatar
Yes mine do but not to loud. After a while they stop. I am going with 272's in a couple weeks and they will tick no matter what. I am sure of it.
Old Feb 24, 2004 | 08:09 AM
gunzo's Avatar
Arpad .. it's called lash adjuster
Here's the check to ensure it is NOT the lash adjuster ..
1.Check that the noise occurs immediately after the engine is started and noise changes with engine speed
2.after engine has warmed up.. noise becomes smaller or disappear .. then it's the lash adjusters ..
according to the manual .. check engine oil 1st .. if low .. top it up .. too high .. change it ..
otherwise assume it's air .. here's the bleeding process
1. Let engine warm up
with no load do the following ..
rev to 3000rpms gradually ( 3000rpms in 15s) lotsa control here to hit 3000rpms in 15s .. release throttle fully
and then rest at idle for 15s ..
repeat .. for 20-30 times..
run engine idle fo 1-3 mins and check that noise has disappeared..
if it doesn't it may not be air trapped inside. .
Old Feb 24, 2004 | 03:06 PM
arpad's Avatar
gunzo: Those are definitely the symptoms, I'll give it a shot. Thanks
navr11
Mar 6, 2016 07:06 PM
EvoRinga
11
Jan 23, 2014 01:30 PM
aceinthesky2002
14
Feb 20, 2008 10:27 AM
drush08
Jan 5, 2008 12:05 PM
jrsimon27
24
Mar 27, 2007 04:04 AM
