Taking off Exhaust Manifold
Was wondering what the difficulty of taking off the exhaust manifold is? I've done a bunch of searching and can't seem to find anything. Is is something that you can do with a torque wrench and a weekend? What else needs to be removed to get it all the way off, and how much of the turbo do you need to deal with, if at all.
Any suggestions would be great. Thanks guys.
To get the exhaust manifold off you have to remove the downpipe, the O2 housing and then the turbo. After that there are only 8 or so bolts that go to the head. It looks easy from the top, trust me I fell for that myself. If you are mechanically inclined you can do it with some jacks or a lift. I'm not, so I left it to a professional
Although 2 of the bolts on the front(closest to the front of the car) are studs that may not allow you to pull the manifold off? Does anyone know if they are studs or not?
If it is as easy as it looks there shouldn't be a worry.
Joe
Joe
Just tried this myself the other weekend. It is not as easy as it appears. Those are indeed two studs on the front side of the manifold. Therefore you would have to take the entire turbo, downpipe, and wastegate assembly off to get the manifold off. I broke down and just drilled and tapped the hole for an EGT sensor while the car was running. This is if that is what you were planning to do.
no what u need to do is take the heatshield off, and the down pipe to make a little clearance for lifting the manifold off the turbo done it a few times, problem u run into is u wanna double check make sure bolts are tightened chased an exhaust leak down to one bolt backing out of mani to turbo....any suggestions???
What I did
spray all the bolts first and wait about 1 hour.
remove the two bolts that hold the downpipe to the o2 housing.
Now just remove all the nuts from the manifold for slack, pull it off.
That's it, you don't need to remove anything else.
It's a lot easier to do if you take the radiater out first or your gonna screw the fins up. Did it last weekend to take the head off to do arp's.. If you need help with anything else let me know. x- mechanic, hvac now..
wowzers
May 2, 2016 02:03 AM
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
4G63_EVO
Jun 30, 2013 03:52 AM
500whp.com
49
Sep 25, 2012 05:47 PM
