EVO RS Trunk Bar Install
Old Nov 5, 2010 | 07:07 PM
  #46
drewbird91's Avatar
Originally Posted by Z_Lancer_Man
I do believe the pitch should be 1.25mm and M10. I'll be at the hardware store tomorrow and I can check my bolt against what they have an actually figure it out for you.
Usually around $60 or so new.
Can you verify the bolt thread? I believe the dealer part number for the RS Trunk Bolts is MS240303-edit it is for sure not ms240303.
Also the RS trunk bar (MR412407) looks to be $41.35 + $9.95 shipping from mitsubishiparts.net
Old Nov 5, 2010 | 07:18 PM
  #47
n2oiroc's Avatar
it is10x1.5 for sure. length isnt important as the hole goes to the ground. anything longer than 17mm or so is fine.
Old Jun 10, 2011 | 10:12 PM
  #48
evolutong's Avatar
subscribed
Old Jun 12, 2011 | 12:48 PM
  #49
drewbird91's Avatar
I went to the hardware store and the m10x1.5 doesn't seem to be the right ones. I'm just going to order MS240129 from the dealer Monday.
Last edited by drewbird91; Jun 13, 2011 at 07:07 PM. Reason: MS240129 not MR240129
Old Jun 14, 2012 | 03:58 PM
  #50
turbotalawd's Avatar
RS trunk bar bolt size
The right bolt size for the RS trunk bar is M10x1.25. Just did an install and figured to post this up to let people know.
Old Apr 8, 2013 | 05:59 PM
  #51
mrfred's Avatar
I've had one of these sitting around for several years. Is it worth the hassle of installing?
Old Apr 8, 2013 | 06:06 PM
  #52
RallyBud's Avatar
From what I have read they do much more on cars that have folding down back seats...less structural rigidity. Evos have the rigidity inherent to them so the rear STB don't provide much...if any...benefit. On my last car (SRT8) I noticed a nice improvement but it had the folding seats.
I'm all ears though!
Old Apr 8, 2013 | 07:13 PM
  #53
My take on that bar is this. Mitsu included it for a reason. If there was no benefit from it, they would not have invested the time & material
If Mitsu is worth their salt, proper R&D testing would have been done ahead of time proving its worthiness.
If it had no worth, the bean counters would have deleted it pronto
Old Apr 8, 2013 | 08:33 PM
  #54
drewbird91's Avatar
If you already have it just install it, didn't take that long, plus you can enjoy doing an easy project on your car.
Old Apr 24, 2013 | 09:35 PM
  #55
Nimpoc's Avatar
I gotta agree with MinusPrevious. New PNs are crazy expensive for an OEM. Please post feedback once installed, +/-, whatever.
Old May 22, 2016 | 02:25 PM
  #56
gsrboi80's Avatar
Just confirming in here installed a RS bar today. Indeed, bolt size is 10 with a 1.25 thread pitch. 30 or 50 mm length work fine, also put #10 lock washers.
Have a rear shock tower Cusco Bar also installed. Can tell it does add extra stiffness for sure on a road test.
Old May 22, 2016 | 03:04 PM
  #57
IMHO / As with any of the chassis braces, any unibody flex is probably measured in the .001 of an inch. Any perceived stiffness / change is likely our imagination
But, I do believe this, Those Mitsu braces were designed & tested & are there for high performance reasons
Old May 22, 2016 | 06:11 PM
  #58
mrfred's Avatar
I've had one of these in my garage since I bought my Evo in 2006. I've always been fascinated by the notion that a brace in this location would make a difference. I guess I need to install it and feel the placebo effect for myself.
Old May 22, 2016 | 06:49 PM
  #59
Makes technical sense to me that when the EVO is seeing track related stresses, these connection points move in space.
But, if the EVO is seeing these stresses, upgraded (not stock) trunk bars, lower sub frame bars & the front upper bars will be needed. The stock bars, are on the light duty side & likely flex when under high stress
Driving the EVO around the block & taking a few hard turns, one will never feel the diff
Old Apr 27, 2017 | 08:41 PM
  #60
codgi's Avatar
Don't know why I didn't read this thread until the end. The MS240129 bolts are too small at least for an USDM '05 regular VIII. The M10x1.25 is the correct size as noted above. This would have saved me 1 extra trip to the hardware store since the first time I got M10x1.5 .
Edit. Got this sorted out with Mitsubishi. The MS240129 is the correct bolt but apparently the vendor they are using to pack the parts made a mistake with the bolts I got. As in the part bag had the correct number, but the bolt was the wrong one. Long story short just go to the hardware store and save yourself the trouble
