EVO Clutch Install, includes t-case removal and service manual links
Old Mar 18, 2009 | 04:46 PM
  #361
MitsuJoe's Avatar
Originally Posted by chasethorpe5126
Do you know off hand if the Exedy twin is any harder to install?
It might take 5 more minutes because you have to assemble the discs/plates. Hardly an issue if you already are doing a clutch job.
Old Mar 18, 2009 | 07:00 PM
  #362
chasethorpe5126's Avatar
Sweet thanks for the write-up, and help.
Old Mar 25, 2009 | 11:41 AM
  #363
VRSF Tiago's Avatar
Maybe it's something simple but when getting everything back together the passenger side output shaft (transfer case to axle) doesn't seem like it's going in all the way and the axle sits about an inch too far from the transfer case.
Anyone experience this kind of problem before?
Old Mar 25, 2009 | 01:07 PM
  #364
MitsuJoe's Avatar
You don't need to remove this output shaft. Is the t-case already lined up with the trans and slipped in?
Old Apr 9, 2009 | 03:53 PM
  #365
awd2gen's Avatar
awesome write up!
Old Apr 11, 2009 | 05:03 PM
  #366
smoke4's Avatar
Is there a writeup anyone knows of for the X?
Old Apr 11, 2009 | 06:09 PM
  #367
MitsuJoe's Avatar
I wanted to make one but it was a hell of a job and I have not got around to it yet!!
Old May 2, 2009 | 05:05 PM
  #368
linuxman51's Avatar
Just got done doing it on my car, spec p-trim twin disc.
Wasn't a big deal. Marginally more difficult than a timing belt only because of the sheer volume of stuff that has to get moved/removed. Took about 5-5 1/2 hours.
All in all, a fairly straight forward process.
Old May 2, 2009 | 07:25 PM
  #369
linuxman51's Avatar
dangit, double post.
Old May 7, 2009 | 11:27 PM
  #370
k20toEVO's Avatar
Saved to my favorites
Old May 23, 2009 | 12:05 AM
  #371
03evo4g63's Avatar
great write up. Just put my clutch in yesterday! thanks again.
Old Jun 1, 2009 | 03:40 PM
  #372
BadBoyBeltran's Avatar
Double-post.
Old Jun 20, 2009 | 01:18 PM
  #373
EvoJay's Avatar
ok well i am replacing the clutch right now in my car... and i cant get off the trans.... it is stuck on the output shaft... no matter how much we pry and shake the trans it will not come off.... anyone have any tips?
Old Jun 20, 2009 | 01:33 PM
  #374
FX11's Avatar
TOB needs to be popped out, or you can do what i did, take out the boot where the FORK is, and remove the Pressure plate bolts so the PP comes off with the tranny
Old Jun 20, 2009 | 02:03 PM
  #375
EvoJay's Avatar
ahhh didnt even think of that!!!! Thanks alot just got it off you helped me alot!!!!!
