Alarm / Security System Help
Old Jul 24, 2007 | 04:35 AM
SuperStreet2K6's Avatar
I bought a car that had a ghetto rigged security system on it and I am trying to remove it and return it to stock. Does anyone have a wiring diagram or a how to for wiring up the stock system? I just want the locks working again with the key fob. If no one even has these things, could you get me started in the right direction by telling me where the stock alarm system is located in the car? I have the dash out right now so it would be easy access if it is there. Thanks in advance!
Scott
Old Aug 8, 2007 | 04:04 PM
Apex VIII's Avatar
You'd probably have better luck in the audio/security section with this post. I'd try that
Old Aug 8, 2007 | 04:12 PM
Apex VIII's Avatar
not sure if this is what you're looking for but this is a wiring diagram for a IX. Best of luck
https://www.evolutionm.net/forums/sh...4&postcount=47
Old Aug 9, 2007 | 03:54 AM
Thanks. Do you have any idea where the unit itself is?
Old Aug 9, 2007 | 09:36 AM
phenaly's Avatar
Here you go - this is the wiring diagram for the Anti-Theft on a 06 IX MR.
It says the Immobilizer is located behind left side dash near the OBD port.
Old Jan 28, 2008 | 04:44 PM
KeithD's Avatar
Thanks I needed this diagram
Old Mar 3, 2008 | 09:17 AM
This should prove to be helpful. The problem is that I think someone just did a crapy job of installing an aftermarket one. I found pieces of it around and a couple modules under the rear seat.
Evoguy!123
Dec 5, 2016 09:12 PM
bee-raddd
Nov 11, 2015 05:57 PM
evoniners
11
Oct 11, 2015 10:51 AM
owenxguo
Nov 6, 2007 04:56 AM
mikesmr8
10
Dec 10, 2006 12:10 PM
