Change Tranny Fluid HUGE DIFFERENCE with REDLINE
Old Nov 14, 2007 | 09:53 AM
bluebyu36's Avatar
ya you should use redline mt90, for the evo trany the shock proof is not that good..for the winter.....
Old Nov 14, 2007 | 10:51 AM
Oil Doc's Avatar
Please.... you are notbeing a pest..... uhhhhh...you're not the one that called me at 3:24 in the morning, are you ?? LOL
Seriously.... The AMSOIL SVG carries a GL-4 and GL-5 rating.. You will be fine until your next change...
Doc
Old Nov 14, 2007 | 11:32 AM
Redline-Z's Avatar
Veteran: Air Force
Full MT-90 due to countless threads I have read stating the reasons and feedback. I am sure a quick search of that topic would yeild you many threads.
Old Nov 14, 2007 | 12:03 PM
Oil Doc's Avatar
And a lot of what I see are people doing "cocktails" where additives can have an adverse effect on each other or running improper fluids such as the lightweight GM Synchromesh Fluids....
Again, where a huge problem lays is that there is no Governing Body over Gear Lubes.... They can say whatever they want on the label.... Even with automotive oils, only about 1 in 5 are close to what they say on the label...
I don't know about the MT-90, but seeing that it is a gear lube, I would think it is comparable to Redline Synthetic 75W-90... Even though it came in 5th place over all, it still failed the tests for Gear Lubes in the 4 Major categories.
Page 19 of the following link will give the over-all test scores of 14 Gear Lubes in Inependent tests.
www.amsoil.com/lit/g2457.pdf
Doc
Old Nov 14, 2007 | 05:11 PM
Redline-Z's Avatar
Veteran: Air Force
Doc
Very informative data.
Old Nov 14, 2007 | 05:12 PM
Redline-Z's Avatar
Veteran: Air Force
Double Post FTL!
Old Nov 14, 2007 | 06:26 PM
LayinLo's Avatar
Been running the Amsoil MTG and I love it so much more than the Redline and stock fluids.
Old Nov 14, 2007 | 08:18 PM
Oil Doc's Avatar
Give me a shout when you are looking for more... Nobody Beats My Prices...
Doc
Old Nov 15, 2007 | 07:08 AM
Davo's Avatar
LOL, Thanks Oil Doc
Will be replacing my redline mt-90 with the Severe Gear this weekend
will let u know what i feel, LOL
I run Amsoil in the engine and said when my dealer got the MTG will go full Amsoil lubricants, guess that time happening sooner than expected
Old Nov 17, 2007 | 12:23 AM
genma's Avatar
Old Nov 17, 2007 | 05:38 AM
Oil Doc's Avatar
Brand of product cannot void a warranty, improper product can...
The Redline May help your shifts, I would take a good look at following link, page 19 will give you the end results.. Whatever you use, be sure it carries a GL-4 Rating.... A GL-5 DOES NOT supercede a GL-4, but some oils may carry both ratings.
Use of a Standard Gear Lube, that is not designed for use in a SynchroMesh tranny, may not totally help your problem. We have found that standard gear lubes, not desined for SyncroMesh Trannies, may "slow" the shifts down slightly causing a missed shift.. Of course if there is already damage internally, no fluid will help.
These tests were performed by Independent Labs and show how Gear Lubes have no Governing Body and can pretty much say anything they want as noted that some neither make grade right out of the bottle, or after tests.
Doc
Old Nov 17, 2007 | 09:46 AM
AWDsub's Avatar
Originally Posted by mifesto
why do i have this hunch user "AWDsub" will be coming back here in 6-12 month complaining "strange noise" coming from his tranny lol
Why do I have a hunch you havent done many track days or have much experience with racing? I have used this exact fluids in my STi for 4 years and 60k miles with no problems.
Thats a very interesting article. If this article is truly unbiased then we all should be running amsoil severe gear. What does it sell for Oil doc?
Old Nov 17, 2007 | 09:51 AM
Redbud23's Avatar
Veteran: Marine Corp
Mine was feeling notchy and did the same thing and put redline in and it was perfect.
Old Nov 17, 2007 | 10:21 AM
cfdfireman1's Avatar
Redline shockproof is a whole different thing too bad Amsoil didn't test that. Maybe they had a reason not to?!
Old Nov 17, 2007 | 11:14 AM
Davo's Avatar
severe gear in and it seems that my tranny was being held back , engine feels totally more responsive
can be used in gl4 apps so its good to go
thanks oil doc for the info
amazing product
