MR gauge package removal
Old Jun 18, 2008 | 04:39 AM
kstpeter33's Avatar
is there a how to on removing the MR gauge panel? I did a quick search bc im at work but didnt find anything.
i already have the actuall gauges out, i just need to know how to get the wiring out...what needs to come out ect..
Old Jan 11, 2009 | 12:49 PM
xceler8rob's Avatar
Bump this up...
Anyone
Old Jan 11, 2009 | 12:52 PM
19DB794's Avatar
The harness that powers the gauges is connected to the radio harness. So you can simply unclip it from the radio harness and remove that but the oil temp is a different story and I'm not sure how to remove that wiring completely.
Old Jan 11, 2009 | 12:58 PM
fromWRXtoEVO's Avatar
Look on evolutionmr.net. I posted there 4 years ago and many other people as well(with pictures). There are 3 type of wires, black for ground, red for power and yellow for the light.
The oil sending unit is plugged into the oil filter assy(I think). The ground has a single black terminal.
It has been a long time since I did one, I also had one on my GSX.
Carlos
Old Jan 26, 2009 | 08:22 PM
bao's Avatar
bao
all i had to do was cut the wires going to the gauges but hooked up aftermarket ones. 2 reds (power)for volt and temp gauge, 3 yellow (illumination/switched power) for 3 gauges, 3 blacks( ground) and joined black and white for temp sensor going to the oil drain plug. you can pull the wire of the temp sender through the firewall, behind the front passenger fender. pics for reference:
evodziobak
Apr 11, 2021 04:32 PM
Amici2120
Apr 26, 2014 03:41 PM
fasolxpl
Mar 13, 2014 09:08 PM
EvoIXPilot
Nov 30, 2012 06:46 PM
DiddePil
Jan 29, 2012 07:23 AM
