HOW TO: Fender Cutting
Old Feb 21, 2009 | 08:09 PM
jid2's Avatar
Over the years I've gotten lots of PM's about fender cutting as I think it is easier and better than rolling. I did my rears a while back. I got new wheels and just did the fronts - so here's the play-by-play.
1. Figure out which areas of the fender lip needs to come off by test fitting your wide, wicked offset baller status wheels. I place a block of wood under the selected wheel so the tire will tuck into the fender.
2. Mark the fender lip. I mark right up to the end of the radius of the fender lip. You can remove even more material (the radius itself), leaving a knife edge fender, but that is harder, and has a much greater chance of leaving an uneven edge that is actually visible.
3. Tape off the edge. If you use white masking tape you can see through to your line. If you use blue, you probably want to tape first, than mark your line.
4. Use a rotary cutoff for the business. An air powered unit makes it a breeze. A Dremmel tool will do it, but it takes much longer especially on the steel double thick rear fenders.
5. Clean the edges with a file, and sand paper if you care to. The rears should be hit with a little brushed on touchup paint to seal them since they are steel. The fronts don't matter as they are aluminum.
Old Feb 23, 2009 | 08:12 PM
chaotichoax's Avatar
Discuss thread HERE!
jid2
120
Oct 18, 2020 08:26 AM
jid2
22
Jan 26, 2016 03:17 PM
jid2
Aug 20, 2009 03:35 PM
jid2
Northwest Region
20
Mar 19, 2009 10:17 AM
jid2
71
Oct 16, 2008 11:27 AM
