How to: Radiator fluid flush & coolant flush
Old Sep 16, 2010 | 06:05 PM
Evoryder's Avatar
Use a measuring cup to get your mix right. I keep pre-made mixes in 1 gal jugs.
Old Sep 16, 2010 | 08:55 PM
evoracing's Avatar
It's a noob question but when your changed your fluid how do you mix your coolant and distilled? I know super noob question but I'm not sure how to get the mix right. I'm here in mississippi so it's probably going to a 60/40 mix as well.
Old Sep 17, 2010 | 07:38 AM
noob12's Avatar
If you don't have a measuring cup or some sort you can always use any household cup. You just have to keep it consistent. If you want a 60/40 mix which is also 3:2, then fill 3 cups of one and pour it into a container and then fill 2 cups of the other and pour it into the same container. Continue to do so until you have enough for your fill. I always keep an extra mix for later use.
Old Sep 23, 2010 | 07:32 AM
fanbelted's Avatar
What about burping the cooling system? I once took off the top radiator cap on my previous car (Eclipse GSX) and accidentally let air in. After that, I kept seeing air pockets show up in the upper radiator hose. I'd squeeze it, and the air pocket would move over to the fill cap area, and I could then add more coolant. But my squeeze method wasn't good enough. My cabin heater stopped working, so I eventually took the car in to the dealer. The dealer said they just had to "burp" the cooling system. I don't know how they did it, but after that my heater started working again.
Old Sep 23, 2010 | 11:02 AM
Evoryder's Avatar
Added extra important step. "Burping"
Old Sep 23, 2010 | 11:27 AM
fanbelted's Avatar
Hey, thanks man! People like you make this a very useful and informative site
Old Sep 23, 2010 | 06:00 PM
Evilution23's Avatar
sweet write up
Old Sep 28, 2010 | 05:40 AM
cij911's Avatar
To answer the question about mixtures - just can also buy pre-mixed coolant (50% water)....
Old Oct 1, 2010 | 04:08 PM
benwara's Avatar
Good suggestion, keep it simple. The jug says what temp range it is good to I live in SD and 50/50 fine.
Old Oct 18, 2010 | 09:50 PM
4g63Moon's Avatar
My heater is broken. I can't turn the heater on.. what do i do then?
Old Oct 18, 2010 | 10:40 PM
Evoryder's Avatar
No heat? Knob is broke?
Old Oct 19, 2010 | 08:39 AM
4g63Moon's Avatar
yeah i can't turn the knob to the heat side. It will only turn to about in between the cold and hot.
Old Oct 19, 2010 | 03:37 PM
LRM1981's Avatar
Are you sure it's broken? Give it a good twist - I just bought a used '03 VIII and I found I really needed to twist the knob hard to switch between the hot and cold setting....at first I thought it was broken
Old Oct 19, 2010 | 05:37 PM
Evoryder's Avatar
you gotta put some muscle in it.
Old Oct 19, 2010 | 06:17 PM
LRM1981's Avatar
Here's all the info you need.
https://www.evolutionm.net/forums/ev...ega-guide.html
