HOW TO NEEDED: Twin disc and hydraulic throw out bearing
Old Mar 17, 2010 | 02:25 AM
  #46
03evoslowtion's Avatar
disconnect at the mastercyliner? all the hydraulic tob i seen line up right at the stock location where the slave lines up.
Old Mar 25, 2010 | 10:16 AM
  #47
picture of the pedal stop.
Attached Thumbnails HOW TO NEEDED: Twin disc and hydraulic throw out bearing-fff.jpg
Old Mar 25, 2010 | 12:01 PM
  #48
awd2gen's Avatar
Thanks for the pic. Now i gotta find something to make that out of... now how do you go about adjusting that for stopping the pedal in the right place? Adjusting a single disc your only really looking for the right engagement spot, now throwing in a stopping spot....
Old Mar 25, 2010 | 09:41 PM
  #49
adjust the pedal all the way out and u want about a 3/4 to 1 inch lower than when it goes into gear without being notchy. use washers and such to adjust distance for the pedal stop.
Old May 13, 2010 | 08:56 AM
  #50
awd2gen's Avatar
03evoslowtion check your PM.
Old Jul 7, 2010 | 11:43 AM
  #51
icantdrive75's Avatar
Originally Posted by 03evoslowtion
i honestly couldnt tell you the exact thread pitch. or exactly how long. just take ur tob to the store and make sure the bolt are about a half inch longer.
The only bolts I found at the store were Class 8.8 ISO which is the equivalent of a Grade 5 SAE bolt. Not enough in my opinon. I found Class 10.9 bolts online which is the equivalent of an SAE Grade 8.
I found M6 x 1.0 x 50 to work for me, I also used lock tite, and a lock washer.
EDIT:
The class 10.9 bolts only came in packs of 15, so it's actually cheaper to go with these Class 12.9 allen head bolts and you gain 26,000 psi of tensile strength!
http://www.nutsandbolts.com/m6-x-10-...-1-p-1929.html
Old Jul 13, 2010 | 02:14 PM
  #52
850RCT9A's Avatar
it tells you how to remove the tranny..then install a new TOB
http://www.evomoto.com/tech_info.php...2b08b02bb2c96e
Old Jul 13, 2010 | 08:59 PM
  #53
OP is looking for a hydraulic specific how-to.
People seem to be allergic to reading these days.
Old May 6, 2011 | 12:27 AM
  #54
rileyschroeder's Avatar
What aabout a hydraulic tob on a 6 speed? Any help with that
Old May 17, 2011 | 09:25 AM
  #55
BlackEvo_5's Avatar
I will be getting a QM throw out bearing soon, you guys really cleared up alot of questions i had .
Old Jun 7, 2011 | 12:41 PM
  #56
BlackEvo_5's Avatar
got my TOB today, so install will be tomorrow and i will let u know how it went....
Old Jun 10, 2011 | 06:34 AM
  #57
BlackEvo_5's Avatar
Clutch is in n car feels alot better, this clutch wants more power, its noisy and aggressive but i love the grip...I now have to move the car about 1500 rpm to not get any chatter, down shift is fun but under 1200-1000 rpm down shifting will strain the rear diff and you will get a diff hop. When first moving off you will hear the clutch engaging and also the TOB sounds like the shaft is spinning between it.
The hardest part is setting the pedal stop NOTE bleed the system, back off the pedal travel (put the pedal away from the firewall) install the pedal stop adjust and den re-bleed the system again than adjust the pedal to where u feel it engage,then adjust the pedal stop about 1/4 to 1/2 from that spot and you are ready once you have all gears selecting without and notching its good to go.
Old Jun 17, 2011 | 11:39 AM
  #58
silentkiller's Avatar
i needed help in installing tilton twin with htob...any picture or step that i must be aware off... 1st time doin htob installation
Old Jun 21, 2011 | 08:04 PM
  #59
Joesforspeed's Avatar
nice
Old Jun 22, 2011 | 04:53 AM
  #60
BlackEvo_5's Avatar
You need help with what exactly Bud?
